Welcome to the site.
You can check the current going to the motor by putting an amp clamp around the blue, yellow, green motor wires.
https://www.newark.com/tenma/72-2985/dmm-clamp-auto-100a-3-5-digit/dp/95Y2983
newark is a division of farnell that has distributors world wide.
You want 6 A or higher with a load on the motor. Wheel up in the air won't draw any amps. 26 A max for a 1000 W motor typically.
You could also check the continuity through the motor wires with it unplugged. Use an ohms scale of a multimeter. Should be 10 ohms or less.
