I would like to use a dropper seatpost on my Haibike Sduro Trekking. Diameter is 31.6 mm.
My need is a bit different from why most people want them. I need the lower saddle height to help me get on and off the bike as I have an ankle problem, not to indulge in brave descents LOL
I have a 52cm frame and I'm 6ft and I usually have my seatpost extended about 4" or 100 mm up for good pedalling action and I should probably have it raised a little more.
Residual from an accident I have limited ankle use on one leg, (brain damage not physical) and my purpose for riding the bike is to improve my fitness and strength as well as agility.
Essentially I would like to ride with the seatpost in an upper position and just drop it quickly when stopping to help me get my feet down on the ground predictably. I would also probably use it when starting off and then very soon after, allow it to come up for better pedalling action. Once i'm going, I have no problems.
Not a youngster LOL.
I don't have a local bike shop with inventory anywhere near me (100 miles) so I want to pick one from mail or online order.
Most of what I have seen online has a length of 450mm or close and because of the Haibike seat tube design with a curve, I think that would be too long. I had to cut 3 or 4 inches off my stock seatpost.
I think I need something with a length of 350 mm and a collar that would allow the saddle to go down to just a short distance from the top of the seat tube. I think I might need to have a "repeatable" upper height position too and i don't know if these posts can do that.
Any help ? Any suggestions? Thanks
