Hello everyone. New subscriber to the forum. I have an issue that I would appreciate some input on if at all possible.
Before I get to the issue I think it's important to go into detail about what DOES work as well as what doesn't if you are asking for peoples' input.
You get a fuller picture. So please bear with me.
It's not actually my bike but my neighbour's. He has asked me to take a look at it because he's has doubts about it's performance.
I have given it a very thorough inspection hardware wise and everything is fine. Throttle and brake motor inhibitors work, pedal assist sensor gap correct and magnetic
field strength seems good and motor controller no apparent issues. Wiring is clean and robust. Mapped it all out and everything seems to be connected that needs to be.
As an endurance test I ran it on its stand with full throttle for 8 hours beginning with a fully charged battery pack just over 40 volts.
The bike has a 5 LED display for monitoring the battery charge state.
During the test I recorded both the LED count and the wheel RPM on a half hourly basis.
After 8 hours of run time the display showed 3 LEDs lit and RPMs were 120 (down from a 132 at the start of the test).
In travel terms this would be the equivalent of 75 miles. A virtual 75 mile ride if you will. Unladen, of course, but as far as I'm concerned it shows the battery pack, the charger
and the motor are working fine.
The battery pack showed 33.4 volts after the 8 hour test.
So, I put the battery pack on recharge. It took 3.75 hours for the charger to show a green light. The battery pack showed just over 40 volts when fully charged.
With fully charged battery pack on the bike the owner took it for a road test.
The feedback is that it works fine. It goes great when he uses the pedals (ie: deploying the pedal assist) and not so strong when he just uses the throttle.
But his main issue is that the throttle has no effect when he is pedalling.
Now I have looked on a nunber of websites and according to the information about combination drives there are two types. One type you can use both the throttle
and pedal assist simultaneously (let's call that Type 1), the other you can't ie: pedal assist overrides throttle (let's call that Type 2).
At the moment my neighbours bike appears to be a fully functioning Type 2. In which case there is no problem.
However, he tells me that it USED to allow him to use the throttle and pedal assist simultaneously which would make it a Type 1.
So here, at last, is my question.
If it began life as a Type 1 and turned into a Type 2 what could be the cause of this? Have you ever heard of that happening?
What component(s) might be at fault?
Throttle or pedal assist sensor? Both appear to be workig fine independently.
Motor controller? After all, it's the controller that's responsible for handling input and output.
Has anyone else had this experience?
Would appreciate your input.
Pic of the bike attached. It's an obscure make. Kiongying.
Thanks
Thanks
