Well, that explains the wobble I have been having.Just a word of caution depending on what eBike you get. If you get a hub motor ebike, with a large weight bias towards the rear its going to give a nasty teeter-totter effect with only a 1.25" hitch when carrying only 1 bike (not so much with a 2" hitch). Rear racks are much more stable if the weight is distrubuted evenly about the center, which can usually be corrected by carrying a 2nd similar bike mounted the opposite direction. Not an issue if the bike carry's its weight in the middle like a mid drive.
Note: the strap helps with fore/aft wobble but not with roll.
This whole "sweating the details" just in thinking of purchasing an eBike is kind of exhausting!!
Hi! Before I buy one of these, I wanted to check with you to see how it has worked out. My Pedego is about 50 lbs without the battery, and I'd like to carry my daughter's regular bicycle as well. I'm a little nervous because of the warranty issue, but I really cannot afford the Thule, and my hitch will be 1 and 1/4 inches. How has your experience been with the Curt 18084? You've used it with an e-bike, right? Thanks for your help!I haven't used this exact model hitch carrier but I did use an older Curt carrier. They work great. $140.00 at Amazon.
Curt 18084 Hitch-Mounted Tray-Style Bike Rack
"New for 2013 are Curt Manufacturing's hitch-mounted tray-style bike racks. The 18084 bike rack offers an easy and convenient solution for transporting your bikes. This bike rack carries two bikes and up to 90 lbs. with either a 1 1/4" or 2" shank. The padded arms easily adjust to fit men's, women's, or kid's size bikes. The tilt away feature allows for rear vehicle access while the bike rack attached to your vehicle. The threaded shank adds stability and prevents wobble while the bike rack is in use. The sides of the rack fold up when not in use, creating a sleek product behind your vehicle. Please keep in mind, any Curt bike rack used with a 1 1/4" receiver tube requires the use of a support strap (Curt 18050). Failure to use a support strap will void the warranty of the trailer hitch and / or bike rack."
Hi Christine,Hi! Before I buy one of these, I wanted to check with you to see how it has worked out. My Pedego is about 50 lbs without the battery, and I'd like to carry my daughter's regular bicycle as well. I'm a little nervous because of the warranty issue, but I really cannot afford the Thule, and my hitch will be 1 and 1/4 inches. How has your experience been with the Curt 18084? You've used it with an e-bike, right? Thanks for your help!
Curt makes fantastic products, you just need to make sure you don't exceed capacities of your hitch, cargo carrier or automobile. This information may be helpful: Understanding Towing.Thanks for your post, J.R. That does look like a good rack. Unfortunately, it's twice the price of the Curt rack, which is rated for 90 lbs total. I didn't think I'd hear back from you so quickly, and I was impatient, so I went ahead and ordered the Curt on Amazon. Uhaul will install my hitch receiver this week for only $146 (no electric work since my car is too old to tow anything anyway!), so I'll see how it goes. If it doesn't seem safe, I may have to shell out the money for the 1Up. It really does look like a great option, as long as I could somehow get my daughter's bike in the car. Buying an add-on rack would just double the price again.I'll let people know how it goes. Thanks again!
P.S. One thing I've been wondering: Does converting a 1.25 inch hitch receiver to a 2 inch hitch receiver change the maximum carrying capacity from 200 lbs. to 300 lbs.? I don't see any 2 inch hitches available for my car, so I'm guessing that the carrying capacity doesn't change--just the dimension of the receiver. I'll ask at U-haul. In any case, another advantage of the 1Up is that is only weighs something like 23 or 27 lbs., whereas the Curt rack I chose weighs close to 50 lbs.!
George S,
I saw your earlier post about the 1up rack and that is the rack I'm most interested in right now. My question, which I cannot find on their website or anywhere else is: will the 1up rack be able to hold one 57 lb eBike?
I sent a message to them via their website (yesterday) but have not heard back. I don't need to carry 2 or more bikes as it's just me.
As for learning to change a back tire (or any tire), I will have to have a lesson on that. I've watched some YouTube vids in the past but that was not for an eBike.
And getting the eBike up and onto a frame hitch rack is going to be something I need to figure out. Maybe I can figure out a homemade ramp of sorts to at least help me from having to lift it all up.
