ElectricJustin2020
Let's say You purchase the Giant Trance E+ 1 Pro because you love the feel of full suspension and you like to hop curbs and cut through trails on my commute but you will never take it in the Mountains and you mostly ride on hilly pavement in the suburbs and you want a better gear ratio that allows you to pedal a slower cadence at high speed and have your most used gears in the middle of your cassette, Would you remove the 3 biggest cogs and slide on 3 higher gear cogs or would you try to find a larger narrow wide chainring or would you just put on a standard larger chainring because the Trance E+ 1 Pro has a shadow+ derailleur???? And if you make this change to your electric bike Do you need to re-tune the engine?? I don't know if you can answer this crazy question but I'm sure you know someone that can. Thanks!
