Elf 180
Mrdi
Can I pick up the rear tire/wheel of an Elf and walk it around so it does a 180 degree turn?
Will Elfs come with reverse?
I don't know if the ELF will ever get a reverse gear feature. I do pick up the rear end of my ELF (by the bar which supports the rear wheel and turn my ELF. Since the ELF weighs ~ 150 lb, I can move the ELF about 10 degrees at a time. Someone who's good at squats could probably move this 30 degrees per move.
