You know of a steel cable that can stand up to a cut off wheel? It seems odd that anything that the average bolt cutter can defeat could be strong enough to hold up under a grinder attack.
If you can tell me how people can thwart a 30,000rpm Dremel tool with a cutoff disc, then this thread will be worth it.
I just got my bike....surface 604 boar, all in $4,700. I live in a condo building with " secure" underground parking. I keep my bike up in my condo. I'm in the process of replacing anything "quick release" with the bolts you can get that are like the locking lugs you get for expensive rims on your car. Bought one of those screaming trembler alarms you can lock to your brake disc or anything else thin enough...and a good high rated chain lock. After all that I'm going to cross my fingers and try not to get too far away from it when I'm out.....wish we could wire them up like a stun gun.
@bikeman242 have a look at these too. I've got one zip-tied under my saddle...they're cheap, loud, and conspicuous.
If anyone bumps, moves your bike, or begins to start working on defeating your lock, it'll be unambiguously telling everyone in earshot (at 113dB) that something's definitely askew about that situation.
I have the same alarm... very effective, but I always forget to bring the remote!
Hehe, yes @FlatSix911 that remote and the battery health are important. I have a journaled reminder in my phone to change the batteries before 6 mos. My only beef so far is that the arming/disarming shouldn't need to be the same obnoxiously loud dB volume as the actual freakout alarm. I find myself walking 100-200ft away from the bike, entering store/market, blending into a busy crowd, and then discreetly arming/disarming it from my pocket.
I have the same alarm. For me it isnt that loud. The alarming/disarming noise is significantly louder than the alarm itself...maybe its broken?
@FlatSix911 , where do you mount your alarm on your BH?
I have the remote zip tied to the bike. A thief might be able to find it but if they are going to take time to find the remote they could quicker just smash the alarm, I guess. If they cared at all.I have the same alarm... very effective, but I always forget to bring the remote!
Why even bother then?
Forgive me, but it's like the folks that pay thousands installing home alarm systems, with monthly monitoring, when they've sticky-noted the defeat pass code to the inside of the key punch pad inside the front door. Is that genius, or something else?
Not quite analogous because the alarm and the remote are not tied together in the same place. Once the alarm goes off they'd be better off trying to kill the alarm than looking around for the remote. That's the way I figure it anywayWhy even bother then?
I wonder why the e-bike motor is usually turned on by a button press if it should be activated by the very same key as used to unlock the battery...
Nowadays it is as if you were leaving your Tesla with the door opened and a button were the only thing necessary to start the car...
Not quite analogous because the alarm and the remote are not tied together in the same place. Once the alarm goes off they'd be better off trying to kill the alarm than looking around for the remote. That's the way I figure it anyway. Probably they would just proceed to cut chains and locks or structures.
Plus if they find the remote and turn the alarm off it doesn't unlock anything.
Not more attention than a bike and gear worth over $15K.Interesting... my experience has been that using a cover draws more unwanted attention. YMMV.
