Ebike battery help
Kenko1974
I purchased a Pendleton ebike for my wife At cheap price but it needs a few bit like battery led display Few cables as in pictures my knowledge is very small it has smart bms battery but do i need a controller unit as I think the original one was built in the battery holder and can’t to see the correct colour or pin connector cables
I see is a motor with a 9 pin motor cable, two handbrakes with dangling brake cables, space in the rack for a battery, and no controller.
You can buy a rack battery and mount the controller elsewhere on the frame, You could also buy a down tube battery with an integrated controller, or a separate downtube battery and controller.
Here's an example of a 36V rack battery with integrated controller/display, I'm just pulling things off the net. No experience with that battery, although I gave purchased a few motors and controllers from this vendor,
Ok thank you I’ve looked at some but that seems as close to the original one as ive seen I will look further anyone no where I might get one in the uk
