Does any have a listing of Bosch error codes and what they mean?
Found them on an old site, very useful https://sites.google.com/a/currietech.com/help/haibike/haibike-race/error-codes
Error Code Description Troubleshooting
410 One of more buttons of the HMI are blocked. Check if any buttons are blocked, e.g. from dirt or debris. Clean the buttons if required.
414 Connection problem of the operating unit. Check connections and contacts.
418 One of more buttons of the operating unit are blocked. Check if any buttons are blocked, e.g. from dirt or debris. Clean the buttons if required.
422 Connection problem of the drive unit. Check connections and contacts.
423 Connection problem of battery pack. Check connections and contacts.
424 Communication error among the components. Check connections and contacts.
426 Internal time-out error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
430 Internal battery of HMI empty. Charge HMI ( in holder or via USB port).
440 Internal error of the drive unit. Restart the system. If the problem persists, contact your Bosch eBike dealer.
450 Internal software error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
490 Internal error of the HMI. Check the HMI.
500 Internal error of the drive unit. Restart the system. If the problem persists, contact your Bosch eBike dealer.
502 Illumination error. Check the light and the associated wiring. Restart the system. If the problem persists, contact your Bosch eBike dealer.
503 Speed sensor error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
510 Internal sensor error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
511 Internal error of the drive unit. Restart the system. If the problem persists, contact your Bosch eBike dealer.
530 Battery pack error. Switch off the eBike, remove the battery pack and reinsert the battery pack. Restart the system. If the problem persists, contact your Bosch eBike dealer.
531 Configuration error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
540 Temperature error. The eBike is outside the permissible temperature range. Switch off the eBike system and allow the drive unit to either cool down or heat up to the permissible temperature. Restart the system. If the problem persists, contact your Bosch eBike dealer.
550 An improper load was detected. Remove load. Restart the system. If the problem persists, contact your Bosch eBike dealer.
602 Internal battery pack error while charging. Unplug the charger from the battery pack. Restart the eBike system. Plug the charger into the battery pack. If the problem persists, contact your Bosch eBike dealer.
602 Internal battery pack error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
603 Internal battery pack error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
605 Battery pack temperature error. The eBike is outside the permissible temperature range. Switch off the eBike system and allow the drive unit and battery to either cool down or heat up to the permissible temperature. Restart the system. If the problem persists, contact your Bosch eBike dealer.
605 Battery pack temperature erro while charging. Unplug the charger from the battery pack. Allow the battery pack to cool. If the problem persists, contact your Bosch eBike dealer.
606 External battery pack error. Check the wiring. Restart the system. If the problem persists, contact your Bosch eBike dealer.
610 Battery pack voltage error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
620 Charging error. Replace the charger. Contact your Bosch eBike dealer.
640 Internal battery pack error. Restart the system. If the problem persists, contact your Bosch eBike dealer.
655 Multiple battery pack errors. Switch off the eBike system. Remove the battery pack and reinsert it. Restart the system. If the problem persists, contact your Bosch eBike dealer.
656 Software version error. Contact your Bosch eBike dealer to perform a software update.
No Display Internal error of the HMI. Restart your eBike system.
Error 500 and 510 both result in a lack of drive or complete shutdown on Performance Line system (both 20 & 28 mph US versions). I've seen these before and never found these descriptions to be very helpful... Does anyone know more details about the meanings, causes, and/or solutions?
