Hacklemedia
Hey, guys! Today we're checking out the Cyrusher XF900. Make sure to subscribe so you don't miss any future episodes
![Backhand index pointing right :point_right: ๐](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f449.png)
Cyrusher XF900 - https://www.cyrusher.com/products/xf900-ebike
![Man detective :man_detective: ๐ต๏ธโโ๏ธ](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f575-2642.png)
![Money with wings :money_with_wings: ๐ธ](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f4b8.png)
![Movie camera :movie_camera: ๐ฅ](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f3a5.png)
![Person biking :person_biking: ๐ด](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f6b4.png)
![Bar chart :bar_chart: ๐](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f4ca.png)
TIMESTAMPS
0:00 - INtro
1:21 - Battery Overview
2:10 - Tires Overview
2:35 - Suspension Overview
3:08 - Cockpit Overview
5:40 - Derailleur, Motor Overview
7:00 - Quick-Release Overview
7:24 - Front LIght, Fenders
8:40 - Battery Removal
9:30 - Supplemental Overview
10:29 - Ride Test
MAKE:
Cyrusher
MODEL:
XF900
PRICE:
$2,800
BODY POSITION:
Forward
SUGGESTED USE:
Off-road, some trails
ELECTRIC BIKE CLASS:
Class 4
WARRANTY:
2 Year Limited
AVAILABILITY:
Canada, United States, Europe, Worldwide
MODEL YEAR:
2020
TOTAL WEIGHT:
74 lbs
BATTERY WEIGHT:
8 lbs
MOTOR BRAND:
Bafang
MOTOR TYPE:
Rear-Mounted Geared Motor
MOTOR NOMINAL OUTPUT:
750 watts
MOTOR TORQUE:
80 Newton meters
BATTERY BRAND:
Panasonic lithium battery
BATTERY VOLTAGE:
48 volts
BATTERY AMP HOURS:
17 ah
BATTERY WATT-HOURS:
816 wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
5 hours
ESTIMATED MIN RANGE:
30 miles
ESTIMATED MAX RANGE:
55 miles
DISPLAY TYPE:
Advanced, 3.7" LCD,
READOUTS:
Charge Indicator, Speedometer, Odometer, Trip Odometer, Pedal Assist Level, Watts, and more
DISPLAY ACCESSORIES:
USB charging port
DRIVE MODE:
Pedal Assist, Twist Throttle, Walk Mode
TOP SPEED:
31 mph
FRAME MATERIAL:
6061Aluminum Alloy
FRAME SIZE(S):
26 in
GEOMETRY MEASUREMENTS:
16.75" Seat Tube
19.5" Reach
34.5" Stand Over Height
28" Minimum Saddle Height
32.5" Maximum Saddle Height
28" Width
47" Wheel Base
75" Length
FRAME TYPES:
Full-Suspension
FRAME COLORS:
Blue, White, Yellow
FRAME FORK DETAILS:
Partner 26โ Front Fork, Adjustable, 110mm Travel, 35mm Deformation
FRAME REAR DETAILS:
135mm Hub Spacing
ATTACHMENT POINTS:
Front Attachment Point, Bottle Cage Bosses, Rear Attachment Point
GEARING DETAILS:
21 Speed Shimano Tourney Derailleur (7x3 crankset)
SHIFTER DETAILS:
Shimano Acera SL-M310 Rapid Fire Shifter, Left, 3-Speed
Shimano Acera SL-M310 Rapid Fire Shifter, Right, 7-Speed
CRANKS:
Prowheel Cranks, 170mm Length
PEDALS:
Wellgo B087
HEADSET:
Gineyea 50.9mm
STEM:
Gineyea 110mm
HANDLEBAR:
Lankeleisi 28โ Overall Length
BRAKE DETAILS:
Tektro, Dual Disk Breaks, 180mm
GRIPS:
Ergonomic Rubber, Non-locking
SADDLE:
Lanke Leisi, Dual Spring
SEAT POST:
CELT Sport
SEAT POST:
30.4mm Width, 350mm Length
RIMS:
White, 80mm Wide
TIRE BRAND:
Kenda Juggernaut 26X4.0
WHEEL SIZES:
26โ
TIRE DETAILS:
30 PSI, 2.1 Bar, Puncture Resistant
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Front Light 6500 Lumens, Kickstand, Fenders, Rack, USB Port in Battery for Charging Phone / Small Devices, Horn, Rear Light (In Saddle)
OTHER:
Locking Removable Battery Pack, Fits Riders 5โ4โ to 6โ2โ Tall, 0.4lb 3 Amp Charger, Max Total Weight 330 lbs
ebike motorcycle moped class 3 fast ebike super fast best buy budget cheap Ebike electric bike review ebike review fat tires motorcycle-inspired goes fast super speed full-suspension go go juice
