Ennovation
- USA
Hey guys! We did a review for the XF690 Plus, but it has been discontinued. The video is not here anymore, but we'll leave all the specs below incase you're curious as to what the XF690 Plus looked like Link to the new XF690 below!
Cyrusher Official Website: https://www.cyrusher.com/en/bikes/XF690
MAKE:
Cyrusher
MODEL:
XF690
PRICE:
$2,200
BODY POSITION:
Upright
SUGGESTED USE:
Neighborhood, Urban, Cargo, Commuting, Light Trails
ELECTRIC BIKE CLASS:
Class 3
WARRANTY:
1 Year Comprehensive
AVAILABILITY:
Canada, United States, Europe, Worldwide
MODEL YEAR:
2021
TOTAL WEIGHT:
66.76 lbs (with battery installed and rear rack bag)
BATTERY WEIGHT:
7.04 lbs
MOTOR BRAND:
Bafang
MOTOR TYPE:
Rear-Hub, Geared
MOTOR NOMINAL OUTPUT:
750 watts
MOTOR TORQUE:
70 Newton meters
BATTERY VOLTAGE:
48 volts
BATTERY AMP HOURS:
12.8 ah
BATTERY WATT HOURS:
615 wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
5 hours
ESTIMATED MIN RANGE:
31 miles
ESTIMATED MAX RANGE:
50 miles
DISPLAY TYPE:
S700 Advanced 3.7" LCD
READOUTS:
Charge indicator, Speedometer, Odometer, Trip Odometer, PAS Level, Wattmeter
DRIVE MODE:
Pedal Assist, 12-Magnet Cadence Sensors, Throttle, Walk Mode
TOP SPEED:
28 mph
FRAME MATERIAL:
6061 Aluminum Alloy
GEOMETRY MEASUREMENTS:
16.75" Seat Tube, 22" Reach, 31.5" Stand Over Height, 23" Minimum Saddle Height, 29.5" Maximum Saddle Height, 25.5" Width, 51.5" Wheel Base, 74.5" Length, Folded Size: 45" x 25.5" x 42"
FRAME TYPES:
Folding
FRAME COLORS:
Red, Yellow, Blue, Green
FRAME FORK DETAILS:
Coil suspension & hydraulic lockout and preload adjustment; 80 mm travel; 35 mm deformation;
ATTACHMENT POINTS:
Fender Bosses, Rear Rack Bosses
GEARING DETAILS:
7 Speed 1x7 MicroNew
SHIFTER DETAILS:
Shimano SL-TX50 (Right Side)
CRANKS:
Prowheel 170mm
PEDALS:
SYUN-LP Aluminum with reflectors
HEADSET:
Semi-integrated, 1-1/18” drop
STEM:
110mm x 31.8mm
HANDLEBAR:
Aluminum 65mm wide with 4” rise
BRAKE DETAILS:
Zoom Hydraulic Brake Levers with Motor Cutoff, Zoom Brake Calipers, 180mm disc brakes
GRIPS:
Stars Union 158 Ergonomic
SADDLE:
LKS Sports
SEAT POST:
LKS 350mm x 30.4mm
SPOKES:
Stainless Steel, Black, 13 Gauge
TIRE BRAND:
Chaoyang 24” x 4” with Puncture-Resistant Liner
TIRE DETAILS:
Max Air Pressure is 20 PSI (1.4 Bar)
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Fenders + Rack Included, Rack Bag, Kickstand, Assembly Tools
OTHER:
Locking Removable Battery Pack, 1.7lb 2 Amp Standard Charger, Max Total Weight 330lbs, 250-lumens front light, Horn
MAKE:
Cyrusher
MODEL:
XF690
PRICE:
$2,200
BODY POSITION:
Upright
SUGGESTED USE:
Class 3
WARRANTY:
AVAILABILITY:
MODEL YEAR:
2021
TOTAL WEIGHT:
BATTERY WEIGHT:
7.04 lbs
MOTOR BRAND:
Bafang
MOTOR TYPE:
Rear-Hub, Geared
750 watts
MOTOR TORQUE:
70 Newton meters
BATTERY VOLTAGE:
48 volts
BATTERY AMP HOURS:
12.8 ah
BATTERY WATT HOURS:
615 wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
5 hours
31 miles
50 miles
DISPLAY TYPE:
READOUTS:
DRIVE MODE:
TOP SPEED:
28 mph
FRAME MATERIAL:
6061 Aluminum Alloy
FRAME TYPES:
Folding
FRAME COLORS:
FRAME FORK DETAILS:
ATTACHMENT POINTS:
GEARING DETAILS:
SHIFTER DETAILS:
CRANKS:
Prowheel 170mm
PEDALS:
HEADSET:
STEM:
110mm x 31.8mm
HANDLEBAR:
BRAKE DETAILS:
GRIPS:
SADDLE:
LKS Sports
SEAT POST:
LKS 350mm x 30.4mm
SPOKES:
TIRE BRAND:
TIRE DETAILS:
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
OTHER:
