I have an iZip Vibe Plus that I bought three weeks ago. Here's my problem: The crank drag is so great that riding the bike on level ground without pedal assist feels like I'm riding a 55 pound bike uphill! I've seen other threads where folks who complain of crank drag are told that it's just the weight of the bike or the fatter tires, but I really do believe it's the drag of the motor. I feel this drag when I have the assist set to zero (or turned off). I feel it when I am at level 1 and try and pedal faster than about 12mph, or level 2 and pedal faster than 16mph. Suddenly, I'm just working and working.
The reason this is such a a problem is that when I ride in the DC area with mild hills, I need to be at level 2 in order to go 14-15 MPH, and I occasionally use level 3 or 4 for larger hills. At level 2, the range should be 35 miles, but I'm getting more like 20-22 miles. I want to take longer rides, but I can't extend the range by using level 1 because I can't go over 12mph, and i can't turn it off because it's just too much work to pedal the bike.
I've been looking at possibly exchanging the bike for a Pedego Interceptor, which would fit my body size better, and offers a higher capacity battery.
My questions are these:
- Is the degree of crank drag I'm reporting experienced by others? Do you also keep your bikes in level 2+ in order to bike the speed you want to bike? How do you get any range on the bike?
- Am I correct that eBikes vary in the amount of pedal drag (though nobody seems to report on this in reviews)? Are there technologies I can look for in the bike specs that would have lower/no crank drag?
- Would the Pedego Interceptor have less crank drag?
