@ 5 Months old Como 3.0 from LBD:
'noticed on the Left crank arm (not chain side) , the outer retainer 'ring' was about to fall off after it screwed itself out from crank center. This is the Outer Ring Nut that screws Counterclockwise into center of arm over center shaft.
... not sure if it is a trim part or actual structural arm retainer.? , appreciate diagram, or link to info on how the Como crank parts setup is supposed to be assembled to work.
Previously I found the Front axle thru-bolt was about to fall off after screwing itself out... ?
I did go over all other fasteners carefully and Blue Loctite'd the loose Ring Nut on crank.
Thanks
Thanks
