Travis0510
Whats the best way to change gears when on an ebike? Do you change gears when you pedal or don't pedal?
Oh ok thank youYou should not stop pedaling as you shift gears.
I’m not sure if I have internal gear hub lol what does it look like?Above applies to derailleurs and multiple sprockets on front or back.
If you have an Internal gear hub (IGH) like alfine or rohloff: In which case you do pause force a bit as you change.
Then Keep pedaling!I have a rear Shimano derailleur and it’s a 7 speed
Oh ok thanks so much I appreciate the helpThen Keep pedaling!
Yeah I gotta get my gears checked out cause I’ve had some cringe gear shifting to wear it’s like clicking and making noisesI try to lighten up the force on the pedals as I'm shifting. Hammering the pedals and shifting with the motor going is really hard on the drive train.
One of my bikes has a shift sensor and one doesn't. It really feels better shifting with the sensor cutting power to the motor.
I've had a couple cringe worthy shifts on the other bike.
Oh ok thanks so much for the helpful infoWith a conventional derailleur, setup without a shift sensor, you run the risk of 'mashing' the gears if you don't lighten up on the pedal pressure when you shift. 'Mashing' is simply shifting under load. It can damage the drive components fairly quickly. As I understand it, this is not covered by manufacturer warranties.
ThisI try to lighten up the force on the pedals as I'm shifting. Hammering the pedals and shifting with the motor going is really hard on the drive train.
