USUALLY, at least 2 magnets will have to pass by the PAS sensor before the motor receives power. How far the crank has to move to do that depends on how many magnets in the PAS sensor. For instance, all else being equal, to get 2 magnets past the PAS sensor, a crank attached to a PAS sensor with 5 magnets is going to have to move twice as far as a crank using a 10 magnet sensor. That's the only practical difference between the 2 types by the way (5 magnet vs. 10). Not necessary to assume more magnets = bigger/better/faster. That's not the case at all.
SOMETIMES though, the controllers are set up with a "sensitivity" adjustment, or a setting allowing you to set the number of magnets that must pass the sensor to your 'druthers. Different strokes you know? Somebody looking for a sensitive set up, or maybe just one magnet passing the sensor, might be somebody riding tight trails where immediate response to the crank is a good thing! Somebody else, saying somebody that might be taken off guard by a sudden/accidental lurch forward, may not care for that sensitive/1 magnet setting at all......
The aftermarket KT controllers, and the Bafang mid drives (UART based), are 2 examples where the sensitivity/number of magnets can be tailored to the riders wishes.
And oh ya. Climbing on board a hyper powerful mid drive with torque sensing may have your attention right quick like. The SECOND time that happens, you WILL have a brake lever pulled when climbing on AND off! Just like a dog only burns it's nose once. That lesson still fresh in my mind.... -Al
