cheese31
I need new brakes for my RadRover Step-Thru. My budget is $500.00.
The stock brakes just don't cut it. I needed to adjust them way too often. And recently they started failing. The front brakes stop working intermittently. This first happened when I was riding down a mountain. Thankfully my back breaks still worked so I could ride home. I haven't gone on a longer ride since. I miss riding my bike.
I plan to get them professionally installed.
I was looking at the TRP ZURICH HD-E810. But these brakes would require that I solder on some connectors. Though I think they are electrically compatible with my bike.
Also, I'm not sure how to find adapters. My rotors are 180 mm. The calipers screw into threaded holes that are 74mm apart. I think that means I have Post Mount. But I'm not sure how to find caliper adapters that would fit my bike so I could get bigger rotors.
- I want more stopping power
- I want levers that sense when I'm pulling the brakes to cut-off electrical power to the motor
- I want low maintenance
