I would like to transport 2 Radrovers. Anyone has experience with tow hitches an bike racks that may do the job?
Thanks
Do have or going to get full fenders and or rear rack? A platform bike rack seems to be easier to use and most can handle the +60 lbs of an ebike. Platform rack can either secure on the upper part of the tires or have a center pole to secure on the frame.
I have a Saris Freedom Superclamp 4 on a 2" hitch I can use between my two SUVs. Usually 85% of the time I just need to carry 2 bikes. I've even removed the Saris second rack arm when I did a trip to the Grand Canyon last fall. I had to purchase 4 larger tire trays for the Radrover 4" fat tires for the Saris rack.
What I like about this rack is:
- it holds both Radrover very secure with no movement
- easy to mount/dis-mount bikes (place bike in tray, strap tires, move rack arm on upper part of tire, and push down to secure)
- the rack can move down to access rear hatch
- small foot print in up position
Dislikes:
- Expensive, $800 retail. I found on Amazon as a return for a little over $500 (it was missing parts).
- Radrover rear mounted kickstand in the up position prevents the Saris rack arm from moving into place to secure on the tire. I have to mount the Radrover with the kickstand down
- My Topeak rear rack is wide and it rubs against the front forks of both Radrovers when on the rack. I found a piece of rubber to wrap around the left forks of both rovers because the paint was starting to rubbing off.
- Fat tires block taillights and my Luna Cycle triangle bag blocks my license plate (issue with any rear rack). I added 4-way AUX light to the rear of the rack.
- Heavy rack, my wife could not put the rack on the SUV (doesn't matter because the Radrover is too heavy for her to mount on the rack anyways)
![rear rack rear.jpg rear rack rear.jpg](https://forums.electricbikereview.com/data/attachments/17/17168-c800e99e2cd083b86835f9aa43e198dc.jpg)
