Aventon Aventure 3 vs Velotric Summit 2
ChrispyjSFL20
Folks,
New here and I am torn between these 2 bikes... I"m 5'11 aka basically 6 even and 262lbs and trying to lose. 70% of my rides consist of social rides downtown on pavement, Trails/traces that are all concrete, and the 30% is light trails on college campuses and parks.. Which bike do you believe is the better bike between the 2 and which would you choose? The stats seem higher on the S2 but the A3 is just a sexy looking bike but my DA can't seen to turn off the superficial portion of my brain/thought process. Please advise. all perspectives are welcome.
Welcome aboard!
The Velotric weighs 20 lb less. That and the non-fat tires will make it a much more agile and responsive bike. Also much easier to get on and off racks and up and down stairs.
The Velotric can handle all the offroad use you describe and then some. If you don't plan to ride in snow or loose sand, think twice about fat tires. They may look cool but bring significant practical disadvantages in daily use.
Most importantly, test before you buy to see for yourself how differently these bikes will ride. And make sure that you can get local service on whatever you buy.
ADDENDUM: Forgot to mention, my wife's Velotric Breeze 1 cruiser is an excellent value. Well-designed and well-made. At only 48 lb with 750W nominal, very responsive. Excellent climber on our many hills, some well over 10%.
Welcome aboard!
Thank you for your perspective. no plans for snow and sand riding but what other disadvantages are there with the fat tire?
Fat tires and their rims are heavy. This adds to both overall bike weight and rotational wheel inertia, and that combo makes for a less responsive, less agile bike that's harder to accelerate, harder to stop, and harder to toss around in turns.
Offsetting those added loads with the motor costs you battery range. Also, fat tires are known for mushy handling and if knobby, for loud tire noise.
Responsiveness and agility are valuable attributes in any bike, including ebikes. Before deciding that the fat tire look is with the price in daily riding experience, you should test some fat and regular tire bikes — even if not the ones you're hoping to buy.
This is good to know. I greatly appreciate your perspective.
I was very close to purchasing a Summit 2 but didn’t like the high cadence of the top gear . The front chain ring was small so my cadence in the top gear was higher than other bikes. I kept attempting to switch to that 1 last gear I was used to when cruising at high speed. I ended with a Aventon level 4 REC . I live on paved surfaces though
thank you for your feedback.. I saw the L4 and feel like my azzz is too fat for that bike
