Aventon Aventure 3 vs Velotric Summit 2
ChrispyjSFL20
Folks,
New here and I am torn between these 2 bikes... I"m 5'11 aka basically 6 even and 262lbs and trying to lose. 70% of my rides consist of social rides downtown on pavement, Trails/traces that are all concrete, and the 30% is light trails on college campuses and parks.. Which bike do you believe is the better bike between the 2 and which would you choose? The stats seem higher on the S2 but the A3 is just a sexy looking bike but my DA can't seen to turn off the superficial portion of my brain/thought process. Please advise. all perspectives are welcome.
Welcome aboard!
The Velotric weighs 20 lb less. That and the non-fat tires will make it a much more agile and responsive bike. Also much easier to get on and off racks and up and down stairs.
The Velotric can handle all the offroad use you describe and then some. If you don't plan to ride in snow or loose sand, think twice about fat tires. They may look cool but bring significant practical disadvantages in daily use.
Most importantly, test before you buy to see for yourself how differently these bikes will ride. And make sure that you can get local service on whatever you buy.
ADDENDUM: Forgot to mention, my wife's Velotric Breeze 1 cruiser is an excellent value. Well-designed and well-made. At only 48 lb with 750W nominal, very responsive. Excellent climber on our many hills, some well over 10%.
Welcome aboard!
Thank you for your perspective. no plans for snow and sand riding but what other disadvantages are there with the fat tire?
Fat tires and their rims are heavy. This adds to both overall bike weight and rotational wheel inertia, and that combo makes for a less responsive, less agile bike that's harder to accelerate, harder to stop, and harder to toss around in turns.
Offsetting those added loads with the motor costs you battery range. Also, fat tires are known for mushy handling and if knobby, for loud tire noise.
Responsiveness and agility are valuable attributes in any bike, including ebikes. Before deciding that the fat tire look is with the price in daily riding experience, you should test some fat and regular tire bikes — even if not the ones you're hoping to buy.
This is good to know. I greatly appreciate your perspective.
I was very close to purchasing a Summit 2 but didn’t like the high cadence of the top gear . The front chain ring was small so my cadence in the top gear was higher than other bikes. I kept attempting to switch to that 1 last gear I was used to when cruising at high speed. I ended with a Aventon level 4 REC . I live on paved surfaces though
thank you for your feedback.. I saw the L4 and feel like my azzz is too fat for that bike
I echo everything that Jeremy said. I work in a shop that sells both. The Summit outsells the Aventon many times over. Fat tire bikes were designed for a purpose, riding at low speed over soft surfaces, like sand. If that is a requirement, then go with the Aventon. The narrower tires on the Summit will not do well on soft sand. However, you said that you will be riding mostly on pavement and light dirt offroad paths. The Summit can handle all that easily. The Adventure will handle like a truck no matter where you ride it. The Summit will ride more like a bicycle. If you can test ride both, you will see what I mean. Both are great bikes, but they are designed for two different purposes.
If you had the chainstay clearance, you could have upsized the chainring to bring down cadence by the same proportion in all gears. Usually a simple inexpensive mod if you can find the right size in the right bolt pattern.
I knew I'd need lower gearing when I purchased my current low-power ebike, so I went the other way and had the dealer replace the stock 44t chainring with a 40t before I even took delivery.
Result: Got the bike I wanted with the climbing gears my legs need in this hilly terrain. The trade-off — higher cadence in top gear — is a non-issue in my case.
At the time it was just out and I went to a sales event at the local dealer both the Velo rep and the bike shop mechanic spent hours looking chatting and said it was not possible. Based on the info I had no option with that bike. I have heard since then it is possible but needed a bike then so went with my best option at the time and very happy so far. Last ride was 122 miles at about 21-22 mph riding time.
MTB style e-bikes (tyres such as 2.25, 2.4 or 2.6") must accommodate the wide tyre so the chainstays are spaced widely apart. The chainstay spacing has to become abruptly narrow towards the bottom bracket. For this reason, the drive side chainstay limits the maximum chainring size. Some commuter e-bikes such as my big Vado with 50 mm/2" tyres are designed long to allow accommodating a big chainring. You would be surprised how long the chain has to be.
For your needs.. S2
Everything previously said, I concur.
Also I see a lot of Aventon when riding. They always look too bulky to me for paved roads .... but this is personal opinion.
I'd swap out the tires on the S2 to something more street oriented for better traction/braking on pavement which will also ride smother, quieter and more efficiently.
Now stop struggling and spend... it's Black Friday!!
It really depends on the conditions you want to ride, Chrispy... Also, not knowing what area you are in, you might look to see if there's any servicing advantage for you location to Aventon vs. Velotric.
One thing about Aventon... If you're looking for a fatty, the mid-drive Aventure M is (by far) the most advanced factory-made relaxed mountain-style 26"er around. I've been hoping to try one someday, but I haven't been in a position (or desire) to replace my (rear hub-drive) Juiced fatty. Perhaps someday.
Another disadvantage and elaborating on my suggestion above is that as far as I know, you'll be very limited in availability of a more street oriented tire... especially from more reputable manufacturers. In the 27.5 realm, you'll have many more to choose from and of better quality.
Another disadvantage and elaborating on my suggestion above is that as far as I know, you'll be very limited in availability of a more street oriented tires... especially from more reputable manufacturers. In the 27.5 realm, you'll have many more to choose from and of better quality.
Definitely. Schwalbe makes a Marathon in 20", but the bikes usually come with a lower quality tire. 20" are also used on folding bikes, simply because they are smaller. Not 4" tires, for the most part.
I recently was helping a friend decide as well as discussions on here and the 26" fatty is pretty much limited to perhaps the Kenda Curser for pavement from a reputable though not the best out there tire manufacturer. My friend went with some Amazon knock off and they didn't even last 500mi and left him stranded when they blew out, not just a flat. But hey, they looked cool 😎
For your needs.. S2
Now stop struggling and spend... it's Black Friday!! View attachment 217826
LOLOL! Thank you for responding
I live in lower alabama. There is one bike shop here that sells the S2 and there are 2 stores that sell Aventon.
Just fyi, here is my list of rides I do
Tammany trace in Abita Springs La 20-30 miles
Longleaf Traces in Miss 20-30 miles
Saturday AM social ride in downtown 10 miles
Weds evening social ride from a brewery downtown 10 miles
another saturday AM ride along the bay call stop and smell the roses 15-24 (sometimes more) miles
off-road
2 local state parks with trails 5-6 miles
RV Park down by the beach, mostly paved but some light trail 10-25 miles
these are the rides I mostly do and Silver Comet is on my BL and shooting to do that March 2027
The Summit 2 checks alot of the boxes with payload, lightness, torque, estimated miles per charge.,etc.. hope you understand where I am coming from
off-road
Betting the Summit 2 will do all of that well, and it'll have local service, too. Here's the EBR review:
