If you frequently fold the bike up make sure you remove the key first, I had a pedal in the "wrong" position and it destroyed one of my keys.
Took quite a bit of searching before I finally found a blank that works for replacement.
Use a Honda X138 (believe this is same as HD75)
Much easier to make sure you have a spare over having to drill out the lock if you lose your other key!
