A easy way to mount a tail light to a rack.
fooferdoggie
tail lights and accessories only mount on your seat post but if you have a bag or rack I the way nope. so I just used a cheap seat tube I had cut a section off drilled a big hole for a tool and a small hole for the bolt and put it on the back ofmy rack. I could also have used a self tapping screw if it did not already have a bolt.
I forgot I did not have a light on back that would be easier actually I would need a different mount the one that came with it is not flat on back. I might change that though it is simpler and no rubber bands to worry about.
