mudflinger
- United Kingdom
I'm a bit confused about two batteries and hoping somebody with more experience than myself could make sense of this...
Basically, I currently have this 48V 13Ah battery running on my bike:
https://www.ebay.co.uk/itm/154421583551
The range is a tiny bit less than what I would like, so I am looking at buying this 48V 17.5Ah battery, which is the same brand as mine and appears to have the same Hailong case / dimensions and 4-pin connector:
https://www.ebay.co.uk/itm/154127955561
I reached out to the seller asking if I could use this battery with the same mount for my 13Ah battery, and they responded saying:
"It is not recommend,it is different current, will not be good for battery.
We recommend to buy 2 pcs 13ah battery."
Unfortunately carrying an extra pack around isn't an option for me a lot of the time, so I'd like to have a 17.5Ah as my "main" battery.
Could somebody help me understand what the seller means? I don't understand why the different current is a problem. Would it be related to the mount/connection for the battery having different specs?
I'm wondering if I swap the mount to the one that comes with the 17.5Ah battery, then occasionally use the 13Ah battery in place of the 17.5, is there a potential for me to damage anything apart from the 13Ah battery?
I am totally ok with it if the 13Ah battery is the only thing that could get damaged. Not so much the 17.5Ah (it's a lot more expensive)
Thanks all
Thanks all
