I was asked about the Shimano Nexus rear hub on the Momentum bikes and I thought it would be a good idea to share my thoughts on the hub here for others.
I love the Transend, it way just the blend of cruiser/commuter/gravel bike I was looking for. I think I've got about 400 miles on it now and so far not a single problem. I let a friend ride mine around the block and she loved it so much she bought one and then her husband got one. His is the black color and it looks really nice. All three of our bakes were delivered to the closest Giant dealer, assembled and ready for pickup within 4-7 days.
The rear hub requires a different riding technique, instructions are included in a sheet that comes with the bike, but so many folks don't read the instructions.
#1 - Unlike a derailleur system, you need to stop peddling and wait a second for the motor to stop assisting before shifting gears. It's really nice to be able to change gears at a complete stop. If you shift while the hub is under a load it makes the internals slip a bit and causes excessive wear.
#2 - Don't 'multi-shift', you can't crank the shifter from #5 to #1 in one motion and the stomp on the pedals, if you do the internals slip. Shift one (click) gear (click) at (click) a (click) time, then you can start peddling.
#3 - There's only one cable on the bike since the brakes are hydraulic. All cables stretch, especially when they are new. The shifter and hub are indexed and the clicks on the shifter and hub have to be in alignment for the hub to work properly. As the cable stretches a bit, things get out of alignment and the hub gets positioned in-between gears when the shifter is set to a particular gear. There is a very simple procedure for checking and compensation for cable stretch. I found that I needed to make a few minor adjustments for the first 200 miles or so and now the cable seems to have broken in and I haven't needed to make any adjustments in a long time. Here's a video of how to adjust the shifter cable, it's also in the manual.
I hope this helps!
