I don't know why you are limiting yourself to a mid-drive if you are a powerful head down flat back racer.  My experience, no display, no software problems. I ride geared front hubs, which are now in US limited to 750 watts.  Wimpy for grocery haulers as I ride, but the brands you mentioned are lighweight racers. You probably do not carry a 10 lb toolbox, 3 tubes, a spare tire, 40 oz water as I do.   A 7 lb geared hub could pep up your hill climbing ability, or reduce your sensitivity to headwinds. 1 lb for the controller, 11 lb for a 17 AH battery.  Yes, the gears do wear out. ~ 5000 miles. Clutches do wear out at about the same distance. My original controller developed a throttle error after 5 years, bad connection on the pcb. The replacement was $60.   The motors in a wheel were $700 or less: just throw a worn one away and install another the same day.  No hassles at a dealer.  I buy my parts on ebay.  If the Amazon truck has not chased you off the road, they have a good selection.  I buy the controllers which require no display, which tend to be for scooters and rotate backwards until I reverse a couple of wires.  Throttle only control,  fine with me. No hill, no >13 mph headwind, I do not need electricity anyway.
