Experience with hub-drives with BOTH torque- and cadence-sensing assist?
Considering the new Velotric Breeze 1 hub-drive for my wife — in part, because it allows you to choose between torque- and cadence-sensing assist while riding.
Anyone have experience with this dual-assist scheme on any ebike?
I'd never choose cadence-sensing assist for myself, but it might make sense for my wife, who likes to pedal but doesn't like the effort needed to ride the torque-sensing hub-drive she has now. Ghost-pedaling might be more to her liking at her current fitness level, but I just can't bring myself to spend money on a cadence-sensing-only ebike.
My evil scheme: Let her enjoy cycling with me with the cadence-sensing option, then switch when she's built up enough strength and stamina to appreciate the advantages of torque-sensing assist Font Generator - 𝓒𝓸𝓹𝔂 𝖆𝖓𝖉 𝓟𝓪𝓼𝓽𝓮.
NB: Mid-drives are out, as she demands a throttle, and I'll only buy a bike we can test from an LBS able and willing to service it. Luckily, we have Aventon and Velotric dealers nearby.
Thanks!
Hi. I moved from a KTM e Cross P to a KTM Bosch-driven bike and missed my torque sensor and experience of the hub drive despite the pitfalls of design. I find up steep hills I have to keep my cadence high to get up. These are very steep hills mind does anyone know of any bikes with a combination of cadence and torque ie pressure sensors? After my less happy experience with the Bosch would be happy to go back to hub drive as well. Thanks.
[Seamless or powerful – most importantly natural. Drive units from Bosch eBike Systems give you a unique riding sensation. Three sensors measure the rider's pedal power, cadence and speed over 1,000 times per second. This facilitates an organic interplay between you and your eBike. ]
Bosch BDU's have like other mid-drive DU's a mix of cadence and torque sensors. With the internal motor controller and the firmware on these systems regulate the behavior of the DU. What you discribe would be a logic for many mid-drive bikes, because they perform better at a cadense around 70 to 90 RPM in general. For simpler systems where the controller moslly works with speed and torque applied to a torque sensor this works a bit different indeed.
At the very least, the Specialized Turbo PAS for their mid-drive ebikes uses rider power, cadence, and wheel speed sensors to determine motor power. Once you have rider power and cadence, you can calculate rider torque.
The result is very impressive, but you need to keep cadence above 70 rpm to reap the full benefit. My 250W, 35 Nm Vado SL mid-drive handles our steep hills (10-20%) quite well at the 80-90 rpm cadence my knees demand.
Detailed explanation and interactive graphical model of the basics of the Specialized PAS here:
In normal riding, rider power is the main determinant of motor power. The user can program the 3 assist levels to modify the relationship through the Specialized app.
The OP was after something different: A hub-drive that can be switched between torque-sensing and cadence-sensing assist on the fly.
Jeremy, I thought I’d note for you here that my Juiced bike lets you turn off torque and go strictly with cadence, but the normal mode is a combination. There is no setting on the Juiced controller to go “only” torque sensor. Aventon and Lectric may do the same thing. BTW, good choices. If I were buying today those two would be at the top of my list.
Caveat: I still haven’t tried riding the bike with pure cadence. Gotta try it sometime, but I’m having too much fun riding the bike as designed. :)
I thought I would throw this out there, it's sort of related to your question. Many of the newer Velotric ebikes, including the Breeze 1, have 15 PAS levels. What I have found on my Nomad 2 is that I don't use all 15 PAS levels. What I DO do is use different levels depending on if I'm in cadence or torque mode. For example, if I'm in cadence sensor mode, I'm usually in Eco, PAS 3. If I'm in torque sensor mode, I prefer Trail, PAS 3 or 4 the majority of the time. So, the 15 PAS levels allows you to find your "sweet spot" PAS level(s) depending on your riding mode. If the ebike didn't have both cadence and torque mode, then 15 PAS levels would probably be overkill.
Agree, any way you cut it, ability to dial in just the right amount of assist for the occasion is a very valuable feature — especially if you like to pedal in a fairly narrow cadence band (82-92 rpm in my case).
Per the official product page, the Breeze's 15 assist levels come in 3 blocks of 5, with each "mode" like Eco or Trail having its own block of 5 tunings. That's one way to get assist flexibility.
My torque-sensing hub-drive does it another way — namely, by offering 9 assist levels in a single block. The levels aren't tunable, but still plenty of flexibility to stay in my preferred cadence band on our local mix of flats and hills.
In contrast, my friend's torque-sensing Aventon Level.2 has only 5 non-tunable levels in a single block — just not flexible enough for my taste. And the lowest level is way too powerful.
My newer power-sensing mid-drive takes both approaches to assist flexibity. On start-up, you have 3 tunable assist levels (ECO, SPORT, TURBO "modes") available in 4 different tuning "presets" (Universal, Battery Saving, Racing, and custom). This vaguely resembles the Breeze approach with different terminolgy.
I ride in the default Universal preset 90% of the time, as it generally gives me all the cadence control I need. But I can also enter Micro Tune at any time from the handlebar. Then I get 10 non-tunable assist levels in a single block — especially handy for matching pace with other riders.
@Jeremy McCreary , that Breeze 1 looks like a nice ride. Unfortunately it doesn’t come with fenders or rack. I like the relatively light weight. That’s sweet. That’s really impressive given the big, heavy hub motor.
Does she have any interest in fatties? If she doesn’t mind a few pounds more (including fenders and rack) maybe she’d like the Nomad fat-bike. The Nomad 1 is pretty inexpensive, although I don’t know how many or if the right size is available. Of course, the Nomad 2 is out there and it’s more expensive.
edit: Oh, I don’t know if the Nomad 1 has all the cool tunability… The web site says it was updated last year, so maybe???
No real use case for a fatty, but yes, the Breeze's low weight is a big attraction in her case.
My theory — soon to be tested, I hope — is that the lighter, more responsive, and easier to handle her ebike, the less it'll just sit in the garage. The Breeze is one of the lightest e-cruisers around, and we'd try it with first without fenders to keep it that way.
The geometry and PAS design are also promising, and I'll soon be able to buy and service one 5 miles from home. Lots of boxes checked here. Fingers crossed that it tests as hoped.
Don't forget the fourth assist mode, that is MICRO, which allows setting the assistance in 10% increments/decrements as you ride*. The fifth mode is SMART, where the App controls the assistance to let you achieve the riding goal. These are the things unheard of with Bosch E-Bikes :)
I would also mention the sixth mode called OFF, which is the one used the most by you, Jeremy :)
How's the progress with the quest to find a throttle e-bike for your wife? I admit I skipped reading this thread! The Velotric Breeze 1 looks nice indeed!
*) Yes, you mentioned it later!
Still waiting for the Breeze to arrive at the nearby LBS for testing, hopefully in the next 2-3 weeks. How that goes will determine what else we test.
On paper, the Breeze looks like her best bet. But understanding what women really want has never been my long suit.
Let her test the Breeze up a significant hill. As you know, hub drives are not the best climbers.
Of a proposition in another thread, I really liked the Ride1Up Prodigy v2. It is an e-bike the best representing my Vado 6.0 (the same 85 Nm Brose TF mid-drive motor and a similar weight of 58 lb, only the 504 Wh battery is rather disappointing). No throttle, diamond frame would probably make it a no-go for your wife. What I'm sure of though it must be a classy climber e-bike! :)
Yes, the climbing test will be key. Based on the way my 500W, 65 Nm hub-drive climbs local hills, the 750W, 65 Nm Breeze should be fine for any climb she's likely to tackle.
Lowering my hub-drive's gearing to 26-99 gear-inches was a big win for this topography. The Breeze may well need lower gearing, too.
Tested the Breeze 1 yesterday. Wife loved it — especially the lower weight (50 lb), more nimble handling, and more pedals-forward geometry compared to her existing 70 lb torque-sensing hub-drive commuter.
As suspected, she also preferred the cadence-sensing assist over the torque-sensing mode. The assist had a little too much delay and overrun for my taste in both modes, but she didn't mind. Did fine on the hill test but really needed a longer hill to be confident about climbing ability.
I tested it, too, and also think that the Breeze would work well for her — except for the throttle, which I'm really hoping was faulty on the test bike.
She really needs a throttle, and the thumb throttles on our existing hub-drives are perfect — instant, progressive with fine control, always available when the motor's on, and totally independent of assist level.
All throttles should work that way IMO, but the one on this Breeze was weak, delayed, and apparently tied to assist level. If it was progressive, I couldn't tell.
The LBS guy knew nothing about any of this. So I pored over the manual, but no obvious settings to address these issues. Will test the throttle on another Breeze at another LBS in 2 days.
My evil scheme: Let her enjoy cycling with me with the cadence-sensing option, then switch when she's built up enough strength and stamina to appreciate the advantages of torque-sensing assist.
Thanks!
We purchased the Velotric Fold 1 Plus last week for my wife. She loves it and uses it in the cadence mode because of weakness in her right leg. This model just came out and it has the new app and controller. It’s very easy to change from cadence to torque right on the screen. I have rode it several times and it’s a fun bike. It’s an ideal very low step thru of 15.75 inches.
it’s our first hub drive, and it’s perfect for her to get her riding again. its definitely a different feeling compared to our Bosch mid drive bikes.
