3 New 04 Yamaha YDX Moro 07 Special Editions
Ken Shopken
Well, our 3 new Yamaha Moro 07s arrived last week.
We spent a bit of time setting up the suspension for our weight and moving stuff about to our preferences. The owners manual unfortunately did not have a section on suspension setups, so we had to go to Rockshocks for specs.
I managed to get my suspension to 30% sag and stay within the maximum recommended air pressure ranges. I am 220lbs. My son Tim however at 275lbs cannot get into recommended pressure ranges so he is running more sag and higher pressures than recommended. The rear is still too soft for him and is an issue when steep climbing. The lockout on the rear shock helps and he runs high fork compression with rapid rebound for now.
My daughter in laws bike has the opposite problem in that she is 5'10" but only 115lbs. She must run very low air pressures, and we are still experimenting with it. She also rides on the large frame (her preference) but the medium may have suited her better.
Frame fit on all 3 bikes is decent for all 3 of us. I am 6'4" and my only complaint is that the stock handlebar is too low, setting below my seat height by about an inch. I am ordering a set of bars that are 180mm higher to reduce some of the wrist strain while riding. I have a pretty good selection of quality handlebars, but none with a 35mm mounting diameter. Choices are fairly limited on the market so far, and this included 35mm stems and lift stems. My son is 6'2" with shorter legs so the bars seem to suit him and my daughter in law. We tilted her bars a bit rearward and her seat forward.
The Yamaha motor, controller and software are incredible. Far more power than I was expecting and what an intuitive power delivery system! There is virtually ZERO trailing assist, which was my main complaint when climbing on my home built enduro with the ToSeven Dm01 mid drive. Power delivery is instantaneous yet very smooth and predictable. I am still experimenting with the automatic assist mode that used a rear hub pitch sensor to dampen response on steep climbs and to cut power on descending trails to save power in automatic mode.
Battery life is impressive. At only 36v and 500wh I was skeptical, but the control system is very economical and efficient. We have lots of long climbs near our homes, and we have already subjected our bikes to a very long and somewhat steep climb on our evening workouts. So far we have only used 1 indicated battery bar, with my sons bike consuming one bar about 5 minutes before mine indicated one bar drop. We climbed about 3 continuous miles in lower gears on eco mode, level 3 of 4 and an additional 4 miles of approach with lots of elevation change. We will get a long ride in this weekend with plenty of elevation change and will get a better idea of how the batteries will do.
Pedaling without assist is much better than I had imagined than it would be and riding on eco mode 1 and 2 is very doable for longest range. Riding somewhat competitively on our road sections, I find myself in eco 3 and 4 most of the time on the climb sections of our evening routes.
The bikes are very stable at speed and yet very agile and playful. They are set up excellent for standing pedaling and climbing. I have already managed to climb a few very tight trails with switchbacks that surprised me that I managed them. The front end is a bit harder to lift than I would have liked (I read that this is due to the long chain-stay) but no doubt contributes to the bikes climbing abilities. The 80mm taller bars should help me out here. I will see.
So far we are very pleased with the machines. A group of local riders that I know have also bought them. We are planning a few group rides over this winter, so as a group we will find out the good, bad and the ugly over time.
The extra battery included in our $1700 plus $75 dealer set up purchases, will be sent out in a month or so we were told. The deal seemed too good to be true, but so far its the real deal!
Nice vid review test of the Moro. Sounds great!
I've had my eye on the Yamaha Wabash RT, particularly the newer, just launching, version that's lighter and has the PWseries S2 drive unit, but unfortunately in UK there has been no Yamaha price drop!
That's too bad you guys in the UK didn't get the price drop..
I would love to have the Yamaha Wabash RT too.
I suspect that the Wabash will have a similar parts support as the Moro. This should add a much longer service life to the product.
I just picked up a pair of Moro 05's.
Could you send over or link any documentation you have on the rear suspension set up? Id like to set ours up.
Download the Rockshox App on your Phone and start there. It needs to be setup by weight and personal preference. There is no one size fits all. Get a shock pump too.
Its a starting point. I think personally the rear shock could use more rebound dampening, but my Shock Pump sucks, leaks, so I ordered a decent one. It arrived but I'm on the road for work and may not ride this weekend. Ill report progress once mine is setup to my satisfaction.
Ken what size was the Allen key to get the crank off?
Trying to install my bash guards
The smaller Allen key is an 8mm but it looks like there is a larger Allen key that you have to remove before that one.
I'm not a Moro owner, but doesn't Yamaha use Praxis cranks? If so, unless they have some unique OEM version, those ISIS cranks are self extracting. Use the 8mm (with a lot of force, maybe even a pipe extension on your wrench) to remove the crank.
The larger M24 bolt is the extractor and is what the crank bolt pushes against to pull the crank off. That is probably 16mm, but you shouldn't need to mess with it normally.
I thought I would report back about the rear shock. I'm 6'5" and 260lbs. I bought the MegNeg Rockshox upgrade kit for this shock. It adds Negative Pressure. I removed 2 Bottomless Tokens, put on 2 of the Bands in the MegNeg (out of 4 total), and was able to run with less PSI that before. This improved the shock performance and let me set the rebound a few clicks out instead of all the way out. I also added a Needle Bearing to the lower shock eyelet from Real World Cycling, part number NBKRWC30. I think if you feel your shock is a bit harsh regardless of your weight, upgrading to that Needle Bearing probably is all you need. Finally 2 of the Battery Caps showed up today from Yamaha, I guess 2 batteries on their way. I bought a 3rd Moro a few weeks later so hopefully I get all 3. Loving this bike so far...
Yes! That looks right thanks so much
I need to buy one of these kits for my bike and my sons.. and the lower shock bearing for all 3 of ours.
Great info.. Thanks for the post!
Great info.. Thanks for the post.
