D
Deleted member 803
Guest
Getting too old to ride a motorcycle so I decided to try an e-bike. Been looking for 2 months and have had a hard time getting concrete information from local dealers on the pros/cons of motor types, suspension types, and componentry.
After riding a Specialized Turbo S, Strommer St1, Eflow Nitro, iZip Dash, Kahlkoff Pro Connect, Focus Aventura S10, Haibike Enduro 29, Stealth Fighter, and about 8 others I was at a crossroads with regards to function and form. I love the new displays from Bosch Gen 2 and Impulse 2 but decided that display was a secondary consideration to fit and motor. I then test rode bikes looking solely at motors and while I clearly understand the differences between mid and hub motors, what I wanted was a speed pedelec that had significant torque. I then looked at frame geometry to suit my octogenarian physique and decided that I wanted a slightly forward lean for optimum core position. From there I looked at tires and suspension that were best suited to paved roads with an occasional trail. My second to last consideration was gearing and decided that 10 gears would suffice and anything more would be ok. Lastly, I wanted a bike I could sufficiently peddle if the battery died.
After much teeth gnashing and an occasional senior moment, I finally decided on a Easy Motion Neo Carbon. While a smaller output hub, the whole bike seems to work very well as a unit. The geared rear hub has significant torque and, believe it or not, was stronger (for me) on significant inclines than a 500W hub.
I plan on upgrading the shifters, adding a Topeak Rack, and an integrated light package with the Easy Motion lighting kit adaptor. I am going to put a deposit down on Monday to order from my not so local dealer.
Would someone like to change my mind? P.S. My second choice would be a Focus Aventura S10.
