Okay after being inspired by another members posting on his install on a Luna bike with the same Ultra motor a buddy of mine took the bait and dove in head first to be another trial test on this set-up.
He went to our LBS to get the bike fitted for his order and we decided to do the install ourselves ourself as we’re fairly handy mechanical wise.
Bit of background here.
We both purchased a couple of Exess HP E-180 bikes with the Bafang Ultra motors including the Archon X1 controller upgrade.
He went with the higher wattage version (2200w) and I elected to go with the standard 1000w motor.
He was previously running an 11 sped Shimano drivetrain with a White Industries rear hub but kept going thru hub body’s because of his heavy hand.
Also tore off his derailer like three different times so he was ready for a switch up.
So ordered up a Sun Ringle Duroc 50 32h rim and I built him up a wheel with a 2 cross lacing with some straight gauge spokes and waited for him to bring the whole kit by.
We pulled out all the parts and set them on the workbench then identified the order of install and got to it.
Removed the rear wheel, chain, derailer, chainring, shifters and then turned bike upside down and unbolted the motor and removed the old derailer cable.
Installed the (2) new shifting cables then buttoned up the motor. Flipped bike back upright and placed it back in the stand.
Fitted up the twist shifter, the brake and rt grip and placed the rear wheel in the dropouts and snugged it up.
Measured and installed the chain tensioner, cut to lenght the shifter cable housings and cables And secured those.
Checked the shifting sequence and verified it was correct.
Ran out of time so we left it there.
Will take some pics when we wrap it up and will offer up a couple of tips for anyone else going this route on their machine.
More later.
More later.
