So, I've had the Fiido M1pro stolen.
The big question is……………WHY did you have it stolen?
You didn’t like it, wrong size, too slow, too fast, the color was wrong, you wife/girlfriend was jealous……the list could go on and on and on and on…..
What should I replace it with ?
You had this bike
If you could?...
You should get this bike...
wOw,, B-52 - I'd Have to Agree. being Honda Motorcycle tech for many years,
I made sure I took home the ProMotorcross 500,, and this guy looks like
it could easily take it's place.
A few times, a month went by to repair my butt to painless state
throw off in the dirt in second gear hill climbing.
But ice studs,, wait till one tries this across the lakes in winter.
Getting near shore line,, a foot of snow is no challenge.
Cheers
Had to see just what a
Fiido M1pro looked like​
This type of front fork design of fork tubes simply supported at the top of tubes
where I have to assume there must be a lot of flex at this point of fork tree
with only an inch of fork tubes inserted.
So if front brake is locked, and body weight moving back and forth, is this in fact true?
Has there ever been total failure and collapse of this style front end?
Surely would leave a mark hitting #6 grit asphalt.
Ah, an American comedian ? How's The Donald treating you ?
It was nicked, thieved, removed, without my permission.
Long story, but I could probably get more laughs than your pathetic pisstake !
In your incorrectly worded title you claim “to had the stupid bike stolen”.
That means
YOU were the cause.
Hence my question as to why?
P.S. I’m not looking for laughs :(
I’m throwing some pity your way……..
So, here's the first question: what kind of terrain are you mainly riding on? You have hills or mostly flat? You want hub drive or middrive? Are you keen enough to invest a goodly amount in this new bike because you know you are going to use it plenty? Or do you have to keep to a budget?
Another folder ebike I figure.
i guess we have to wait for a response because
"What should I replace it with ?"
is vague.
I've tried to warn them - if it falls over in water,, Do Not put it in bag of Rice.
Sure enough Below Deck Steward brings bag of rice to gal who drops phone
in hot tub, I just about lost it with this ongoing retarded mindset.
When electronics are process in dry high heat of 400F,
and after a week in cold wet moldy special sauce, every micron of electronics
has full on corrosion with active battery @!
Cheers
Wow just wow! What happened to this place? Guy gets his bike stolen, comes here for some advice and gets clowned for the wording of his post, a post that everyone clearly understood! Super lame imo.
I'm not following maybe. A guy gets his bike stolen and he's looking for a replacement. No further info.
Personally speaking, I find it kind of silly to be playing a guessing game given the amount of info he's shared to this point. If he's serious about getting some decent responses, he needs to share more info.
And pissy attitudes help nothing.
See - One Shouldn't Need to Ask any of these Questions -
All that's needed now is the PO lice report,,, then pile on the links,,
will be much easier, and a heck of lot more Fun @!
* Here's 50 to start with,
just viewed moments ago on Smart Tv,, not some little 6" screen.
Smart Tv gets stream from Laptop.
See one that makes a mark,, hit screenshot, and start making folder.
I can show the folder I just made,,
Cheers
