I’m looking for a pair of ebikes to hang off the back of our RV. We’re pushing 60, reasonably fit but haven’t ridden much in years, both 5’8” (I’m heaviest @ 175lb with the shortest legs 29.75” stand over).  We initially thought of folding bikes but then they’ll be in the way inside the RV and they’re often heavier then the same brand’s non-folding models, however non folding means more exposure to the elements (road salt etc). I was thinking a step thru and a standard frame so the stiffer frame could carry more groceries but a lot of the stand over heights are pretty close to the end of my stubby legs, the Aventon is the exception, so maybe 2 step thrus instead? The pandemic means we’re not travelling imminently so I’ve got time to over analyze.
I’ve decided front suspension, fenders and a rear rack is a minimum, integrated lights are a should have, USB charger to aid phone navigation is a nice to have. I’ve narrowed it down to 4 brands/models, given periodic sales and shipping to Canada they’re more or less the same price. I wanted to rate the Aventon 1st but no-throttle from a standing start seems like it would get annoying if you’re stopped for traffic lights.
I’m curious to get the group mind opinion, or any other brands I’ve overlooked.
Thanks!
Ride1up 700 (or 500?) 1st choice
Pro
Step thru handlebars give more upright riding position.
Integrated lights
Battery placement is subtle w/ minimal exposure to elements.
Open box deals available
Cushiest seat? Potentially won’t have to buy a suspension post?
Bungee for rear rack included
Hydraulic brakes (only 160 rotor)
300 Lumen light
12 gauge spokes front
Con
More assembly required
Kick stand in the way of pedals (700 only)
No USB
29.5 stand over
smallest front fender
Neither/unknown
Non Kendra tires (does that matter?)
Any water follow the cables into the frame?
Is a 500 enough? 500/w fenders not much cheaper then 700
Do we really need 27mph?
Is the stepthru/regular really the same weight?
Magnum UI6/UI6+ 2nd choice
Pro
Suspension seat post included for the price
Dealer option available (not local and higher price)
Derailleur guard
29.25 stand over
USB
Con
Semi integrated lights, unknown power
Mechanical brakes
motor inhibitor on front brake only
Minimal looking rack (no pannier guard, cantilever bracket)
Out of stock
Battery looks pretty exposed
13 vs. 12 gauge spokes
Dangerous looking water bottle studs UI6+
Neither/unknown
Contacts exposed to elements when battery removed?
Is a UI5 enough bike?
Rad City 3rd choice
Pro
Higher rack capacity (welded in makes the frame stiffer too?)
Popular brand (or is that just Google algorithms?)
Chain guide, derailleur guard included
Lots of add on rack/basket options.
USB (1amp)
12 gauge spokes
Con
Level 2 only
Twist throttle (not sure if that’s a con so much as a difference)
Weak 80 lumen headlight
Heaviest
Battery looks pretty exposed.
Website always seems to be backordered for something
Mechanical brakes. (180 rotor)
Lots of exposed cables.
29.5 stand over
Out of Stock
Aventon Level 4th choice
Pro
Arguably the prettiest of the bunch
3 amp charger vs. 2
Lightest? (aventon sight says 62lb/EBR says 58)
Biggest brakes hydraulic 180 rotor
Dealer option available (but not local and higher price)
Chain guide front sprocket.
Lowest stand over height.
Wide handlebars
Con
No throttle from stationary (deal breaker?)
No lights.
13 gauge spokes, lots of reports of breakage.
Neither/unknown
Do we really need 27 mph?
USB?
Thanks!
Pro
Integrated lights
300 Lumen light
Con
No USB
29.5 stand over
Neither/unknown
Pro
Derailleur guard
29.25 stand over
USB
Con
Mechanical brakes
Out of stock
Neither/unknown
Rad City 3rd choice
Pro
USB (1amp)
12 gauge spokes
Con
Level 2 only
Heaviest
29.5 stand over
Out of Stock
Pro
3 amp charger vs. 2
Wide handlebars
Con
No lights.
Neither/unknown
USB?
