Wiring retention ion 48 volt bike
How to trouble shoot error ten code
  • I checked lcd I checked connectors and also couldn't find shortage in wires
    Votes: 0 0.0%
  • I would think rewire the whole bike
    Votes: 0 0.0%
  • Get new control and connectors to lcd check motor
    Votes: 0 0.0%
  • Total voters
    0
Mike157
Error ten code what to do...I checked wires I check connectors sensors and lcd screen wires ....so
I meant I have a ion reention bike with fat ts
Can I wire ebike throttle only?if so can I see a diagram
Mike, you'll collect much more information if you supply a little more. Instead of appealing to just those familiar with your Ion Reention bike (I've never even heard of one), and how it's wired, maybe supply a little more info about what you are doing and some higher quality photos.
I'm left wondering-
Does the bike have a throttle now? Are you sure it's able to use a throttle? What brand motor? Hub drive or mid drive? A CLEAR picture or 2 taken from the rider's seat would be a big help as well.
And last, you need to realize some bikes are not able to use throttles due to motor design....
Best of luck.
Reention is just a battery manufacturer, they don't make actual bikes (or controllers/displays). They made your battery basically
Can you take some more pics of your bike and/or identify a few things:
1) Bike mfr (some side pics and pics of any labels on the bike)
2) There should be a name/model on the motor can you snap a photo
3) Can we see pics of the display
Q: How to trouble shoot Error 10.
A: First you find out what it means. Every brand of display has its own list of error codes, and no one uses the same list. Even displays that use the same case and LCD screen may have different firmware and use completely different codes.
If you have an owners manual, see if it shows the error codes. Picture of the LCD might help.
