I have an Xtreme rubicon 36v 350 rear hub motor. My question is: what should the display wattage read at verious levels of assist? 5 levels available, level 1 reads 25-28 constant, no change when pedaling. Level 2 sometimes goes to 50-51, constant. Level 3, 4 & 5 the wattage levels keep changing depending on the amount of pedaling. If I slip the chain off the chainring and crank by hand I get the same result with minimal assist at the wheel. I can not notice any assist at levels 1 & 2 when riding, but definitly at levels 3 and above. I have been going around in circles with Allco Manufact. for months now. They have replaced the controller and display but this did not correct the problem. Sent the back to them($125), they said it was the battery, sent it back to me. Can't tell if it is a new battery, but the problem is the same. Display reads the same. Does this sem correct. Any input would be helpful.
