Thanks for the tip! Which model 1Up did you settle on?I just got my two Aventures and was having the same problem. There is a Hollywood rack on Amazon that can carry up to 100 lbs per bike. The ASIN is: B08HJTFN64. I ordered it and received it but just as it arrived I was notified by 1Up that I could order their rack (they are backlogged). So I am returning the Hollywood and going with the 1Up. Check them out at: www.1Up-USA.com. I liked their setup better. Hope this helps.
@dfaulk how is the 1up treating you? Are you using it with a bike that has fenders? I am thinking of getting one but I am concerned about the pressure of the mechanism on the rear tire fender. I dont want to have it crack and break while driving on bumpy roadsI got the 2” Super Duty Double in black. It is going to arrive tomorrow so they turned it around fast.
Not a question. A rack with a keeper bar that clamps down on the tire will not work with a bike that has fenders.@Browneye Sorry was that a question or a statement?
I assume you mean like most Kuat that just have a single "hook" that pulls over a tire.other racks
At first I noticed 1Up's comparison table indicated that the Super Duty 2" Double rack you acquired could only handle a 3.1" tire (the Aventure tire of course is 4"). However, further research on their website indicated they sold a fat tire spacer kit for $34 that expands its capacity to 4.9". Great! Please re-post here to let us know how the rack works with your two Aventure bikes (I'm getting two myself so am keen to learn). May I ask separately what "better setup" on the $625-$679 1Up rack was compelling enough to return the Hollywood rack which can often be obtained between $450 and $500?I just got my two Aventures and was having the same problem. .....I was notified by 1Up that I could order their rack (they are backlogged). So I am returning the Hollywood and going with the 1Up. Check them out at: www.1Up-USA.com. I liked their setup better. Hope this helps.
^^Looks good. But the frame-hold bar would be a non-starter for me.
The rocky-mounts main frame bar rises higher after the hitch insert part, creating a lot higher ground clearance. Not sure about others, but I think Kuat's do as well. Hope you don't drag on driveway aprons with the 'fultyme'.
