Right, a pusher trailer, I think that I've seen a single wheel pusher trailer commercially available. Thanks for the link - it looks like they were talking about high power heavy/heavily loaded. The aluminum single wheel trailer that I have is very light weight and it wouldn't be loaded too heavily. My main concerns are if the dropouts are strong enough (I can make torque arms) and if the axle skewer that connects to the trailer is strong enough. I have tested the trailer stock with 50 pounds load and it was very stable.So you're considering that this would be a 'pusher' trailer where the trailer's hub motor can be used to help push the trailer and the conventional bike it's attached to? I toyed with a similar idea several years ago but decided against it based on threads like this one; https://endless-sphere.com/forums/viewtopic.php?t=97691.
I have had a trailer for a few years already, just want to try adding the motor which I have already laced into a 16" wheel as shown in the image.Why not just buy one thats already made ? Google showed a bunch .
@Rich Wolf is a member here, he made exactly what you are describing, a pusher e-trailer, and developed a few models. I remember Court doing a review of one. I don't think the company is still in business and there is a new (no affiliation as far as I know) ebike company using the name now.The trailer I have is identical to this one. It has an axle skewer attachment.
The motor I have doesn't provide enough assist to be helpful on steeper hills where I want help but in the 16" wheel it should provide 1.6x the torque effect vs when it was in a 26" wheel. I'll have to just give it a try to see if it works well in this application. The spokes and 16" diam rim were only ~ $30 so it is a cheap project.
I want to use the motorized trailer with a regular pedal bike, not my ebike. I did a 3 day 175 mile tour route in eastern Oregon this past summer on my Yamaha powered gravel bike. It did really well overall but the frame isn't as sturdy as my Walmart Schwinn bike. With panniers on the back it felt like the rear of the frame was flexing when I would stand to pedal up hills. I also took the Walmart Schwinn on a 2 day 120 mile ride in Idaho a week or two earlier. Overall I like that bike better but would have appreciated some assist. I don't want to add a motor to the Schwinn because I don't want to make it a heavy bike, a mid drive would also take away the triple chainring and I would lose the wide gearing.I get a kick out of this I had pulled a 200# loaded trailer on my recumbent 10 miles. a e bike should do Fien without a motorized trailer.
Nothing new , they have been around for quite a while just never caught on big .@EMGX The whole time I was reading this thread I was envisioning a trailer that attaches to a seat post with a pivot and thinking that it's guaranteed to jackknife as soon as you hit the throttle. Seeing that the trailer has a rigid attachment to the bike via the rear axel makes me think this might work, provided you have enough weight on the trailer so the hub motor wheel has sufficient traction. Keep us posted with updates and photos, this is going to be interesting. Maybe you have stumbled onto a way to add electric boost to any bike with a rear skewer!
Thanks, I hadn't seen that. Same idea but he uses a direct drive which would add some resistance when the motor wasn't being used. The geared hub motor I have freewheels without added resistance. I don't plan on using the motor assist except when needed and I don't need to go as fast as he does, nor ride without pedaling. The top speed of the motor when it was in a 26" wheel was a bit over 20mph so it should top out around 12 or 13 mph in the 16" wheel, that is fast enough since I would only use on hills or into the wind where my speed would be low anyway.@Rich Wolf is a member here, he made exactly what you are describing, a pusher e-trailer, and developed a few models. I remember Court doing a review of one. I don't think the company is still in business and there is a new (no affiliation as far as I know) ebike company using the name now.
Maybe some inspiration. He used a really well constructed wheel and motor. You should be able to use what you have. You can look back at Rich's posts for more info.
I wouldn't expect that there has been much of a market for something like this. I wouldn't have even considered it except that I already have the trailer and the motor. The only expense has been to buy the 16" rim and spokes so I thought I would give it a try. If it does work well I plan to use it for some short touring this spring.Nothing new , they have been around for quite a while just never caught on big .
I do plan on making some simple torque arms that will butt up under the stays since the rotational torque would be counterclockwise. I'm motivated to finish it up because I'm curious if it will work in a useful way but it is too cold in the garage to spend much time on it. Not sure if I will put the controller and battery on the trailer or on a back rack on the bike, probably on the trailer. I have touring plans for it if it works really well.Looks like it fits just fine. Are you planning on carrying the controller and battery on the trailer?
One suggestion is to make a small torque arm that goes from the axle up to that braze-on. It would take the place of the tab washer, which in my mind are pretty useless at handling torque loads, and you would still be able to attach that stay using a little longer bolt.
You will have fun with it for sure.
