Jim Laslett
Hi
I purchased a specialized turbo Levo for expert 6 fattie 18th January 2018 the chain has snapped and bent the chain guide. This has only taken 28 days which I’m am shocked about.
I have barely used this bike and I was using it to walk the dog this morning. This happened from a standing start as soon as a started to ride.
I am a qualified mechanical engineer and have two other specialized bikes (not electric)
This is a design fault, the chain is not strong enough for the torque of the motor. I have lost confidence in this product and believe this will be a on going problem.
Rutland cycles have this reply:
Hi Jim,
Thank you for your email and the images. Due to the size of your original email I have been unable to reply in the same chain.
We are sorry to hear that you have experienced issues so early on.
Unfortunately chains are a wear and tear part and on occasion a chain may snap due to several circumstances not limited to; starting off in the wrong gear, shifting under load or having debris entering the drivetrain.
The torque of the motor will not be a factor in the sudden failure of the chainlink. The Levo motor produces at most 700-800w most chains are able to withstand over 2000w regularly.
To rectify this issue all you will need is a split link to join the chain back together, on some Levo's one even comes with the bike, located in the top cap area.
As the issue can be repaired and the bike has been ridden it cannot be returned.
Best regards,
Danielle
Customer Services
E: [email protected]
T: 0330 555 0080 lines open Monday to Friday 9.30am-5.00pm
Best regards,
Customer Services
I’m struggling to see the customer service ?
Hi Jim,
Best regards,
Danielle
Customer Services
Best regards,
Customer Services
