Does anyone know what size insert and tube you need? The tires are 28”x 1.75” . Thank you
R rjathon Member Region USA Mar 24, 2022 #1 Does anyone know what size insert and tube you need? The tires are 28”x 1.75” . Thank you
Rickman1 Active Member Region USA City Aridzona Mar 24, 2022 #2 rjathon said: Does anyone know what size insert and tube you need? The tires are 28”x 1.75” . Thank you Click to expand... Just shoot Tannus an email with your question. They will get back to you pretty quick with an answer. That's what I did. You can also buy the correct Tannus inserts with the correct size (smaller) tubes that you will also need from them.
B Brendon@OEB Well-Known Member Mar 31, 2022 #3 rjathon said: Does anyone know what size insert and tube you need? The tires are 28”x 1.75” . Thank you Click to expand... You'll want the Tannus 42-47 size, it's a touch on the small side but installation is easier. Tube size should be 700x28 or so.
