Tektro HD-E745 - Parking brake, 2.3mm rotor
Timpo
Ho do you buy this brake? Can't find it anywhere. Does it use standard HiGo connector for the sensor?
Yes.
It's mostly meant for OEMs and not sold through retailers but that may change in 2021. We have a brand new one if you would like.
We have since then switched to Magura and don't need it.
We also have this one:
Yes.
Is it just the right master cylinder and the two calipers, or is there a left hand master as well? I do a lot of cargo hauling as I think I've mentioned in other threads and this is for a new dual-motor DIY build; I really like the parking brake feature and no-one else has that. That said, the cinchies that come with my clik-stand will work fine and I'm also considering MT-5e's... but I installed a new pair of MT-5 E-stops (same brake without a sensor) on my R&M Homage and have not been thrilled with the bleeding experience with Magura brakes. I've bled them a couple of times following the official Magura videos (of which, maddeningly, there are 3, all of which are slightly different), and I still have to perform an occasional 'dirty bleed' where I top off the master cylinder, even though no leaking is apparent anywhere in the system, and I'm not over-tightening the fill port bolt, because they fade quickly and permanently after a few rides.
Yes.
Hi, would you still happen to have the Tektro brakes? namely the dual caliper and single lever version? I have a cargo bike that Iʻm trying to upgrade to hydro brakes for the 2 front wheels. I just put a 4-piston hydro brake for the rear and itʻs such a great upgrade to have the modulation. Thanks!
Sorry, that one is sold!
