I have to fix a flat on the rear of my ST5. Does anyone have some instructions or tips to share? What is the tool needed to remove the center bolt on the rear hub? Thanks
If you bought it prior to 2019, then it has a Torx T70 bolt and you may need to get that to be able to remove the wheel. Regular Torx won't work.
Otherwise, it is a pretty simple process.
Loosen the axle bolt and disconnect the power cable. After this point, it is just like a regular bike.
