RandallS
- Canada
- City
- Calgary
My wife is selling her Di Blasi R34
The Di Blasi R34 folding electric tricycle has a unique mechanism that folds into a cube in seconds. It will fit through a door space of 35cm
The easy folding of the R34 makes storage more practical and significantly increases the trike's versatility.
Suitable to fit into a car trunk, motor-home, camper van, boats and small private planes.
Purchased September 2018.
Purchaser has MS and disease has progressed and is unable to use the bike anymore.
Used it 5 times in 2019.
Original cost $4,670.00 .... asking $3,400.00 or best offer.
Will ship, purchaser pays shipping from Calgary
Details:
The Di Blasi R34 folding trike has a low step through frame which makes it easier to ride. It is particularly adaptable for older adults and those with minor physical handicaps.
Electric Motor
The R34 is equipped with a ‘pedal-assist’ electric motor.
The motor is active only when your pedals are turning.
The output of the motor decreases when you increase the speed of the pedals.
To pedal without the aid of the motor, just turn off the switch.
FEATURES:
GRAPHITE GREY COLOUR
+ 25km / 15 Miles per charge on flat roads, without pedaling*
+ Maximum speed without pedaling is 6 km/h / 3.7 mph
+ Maximum speed with pedaling and pedal assist is dependent on rider input*
+ High tensile carbon steel frame
+ Painted with polyester powders.
+ Step through only 19 cm / 7.5" from the ground
+ 20" wheels / 48cm
+ Folding pedals
+ Extra padded bicycle seat
+ Rear Basket
+ Folded pull handle to wheel while folded
+ Motor: 24V 250 Watt
+ Charger: 2A
+ Battery: Lithium (LiFePO4) 9Ah
+ 5 speed twist grip gear changer with derailleur
+ Two V brakes on front wheel - with one functioning as a parking brake
+ Battery-powered front and rear lights
+ Bell
+ Mudguards(fenders)
* Rider Weight and Terrain Contingent
DI BLASI SIZE CHART FOLDING TRICYCLE SPECIFICATIONS
STANDARD size
Motor 24V 250 Watt
BatteryLithium (LiFePO4) 9Ah
Charger2A
Height of the seat from the ground 90cm / 35.5" adjustable down to 81cm / 31.9"82cm
Height of the seat from the pedal placed in the lowest position 84cm / 33" adjustable down to 73.5cm cm
Height of the handlebar from the ground 100cm / 39.4"100cm
Distance of the seat to handlebar 43cm / 16.9"
Chain ring 42 Teeth
TeethCrank Length 170cm
Tires 48cm / 20"
Maximum Load on Rear Rack 10kg / 22lbs
Total Maximum Load Including Rear Rack Load100kg / 220lbs
DIMENSIONS:
+ Folded - Length 68 x Width 28 x Height 62.5cm / 26.8" x 11" x 24.6"
+ Unfolded - Length 68 x Width x 69.5cm / 27" x 61" (Height adjustable with maximum of 82cm / 32.3")
+ Weight Without Battery 21.4kg / 47.2 Lbs
+ Weight with Battery 27.5kg / 60.6 Lbs
STANDARD size
Motor 24V 250 Watt
Charger2A
Chain ring 42 Teeth
Tires 48cm / 20"
Details:
Electric Motor
FEATURES:
+ 20" wheels / 48cm
+ Folding pedals
+ Rear Basket
+ Charger: 2A
+ Bell
STANDARD size
Motor 24V 250 Watt
Charger2A
Chain ring 42 Teeth
Tires 48cm / 20"
DIMENSIONS:
STANDARD size
Motor 24V 250 Watt
Charger2A
Chain ring 42 Teeth
Tires 48cm / 20"
