steve mercier
I would love to hear input from anyone who has extended experience with one of these.
Thanks Mike that is good input! The bike I had in mind uses a chain with the Nexus 8. My guess is most people never do any maintenance on these at all and I wonder what kind of longevity they end up getting.
I have owned two bikes with a Shimano Nexus rear hub. One was on a Breezer Uptown with a 750 watt front hub motor. I bought it used and put 2500 miles on it. It acted flawlessly and never had an issue shifting. I have one on my 2019 Electra Townie Commute Go 8i. It is an 8 speed internal rear hub. The motor is a mid drive Bosch Performance 250 watt motor. I am careful when I shift, usually pause, not to stress the hub. I have close to 1000 miles on it. I like that I can shift to a lower gear, while standing at a traffic light. It has not been great. I seem to have two issues. When shifting it is slow to shift into gear. Second, no matter how many times I or my LBS work on it, when in 5th gear, it will inevitably skip. I was told it was finicky and had to be adjusted just right. After numerous times, I asked if I could have the rear hub replaced, under warranty, I was told Trek wouldn’t authorize it. I will eventually replace it.I would love to hear input from anyone who has extended experience with one of these.
Thank you for you input. Do you think the front hub motor is easier on the Nexus then?I have owned two bikes with a Shimano Nexus rear hub. One was on a Breezer Uptown with a 750 watt front hub motor. I bought it used and put 2500 miles on it. It acted flawlessly and never had an issue shifting. I have one on my 2019 Electra Townie Commute Go 8i. It is an 8 speed internal rear hub. The motor is a mid drive Bosch Performance 250 watt motor. I am careful when I shift, usually pause, not to stress the hub. I have close to 1000 miles on it. I like that I can shift to a lower gear, while standing at a traffic light. It has not been great. I seem to have two issues. When shifting it is slow to shift into gear. Second, no matter how many times I or my LBS work on it, when in 5th gear, it will inevitably skip. I was told it was finicky and had to be adjusted just right. After numerous times, I asked if I could have the rear hub replaced, under warranty, I was told Trek wouldn’t authorize it. I will eventually replace it.
What do you guys think about this bike?A friend has an Electra Townie from the days they were made in WI. With a Nexus 7 speed. I think the bike was sold to him in 1999-2002. He isn't clear. Last year he had a rim fail and the hub was reused and certified no issues by our local LBS.
The only issue running a mid-drive and Nexus is shifting under load. A shift sensor solves that issue with higher-powered Bafang mid motors.
Cool.A friend has an Electra Townie from the days they were made in WI. With a Nexus 7 speed. I think the bike was sold to him in 1999-2002. He isn't clear. Last year he had a rim fail and the hub was reused and certified no issues by our local LBS.
I do believe that. As much as I like my Nexus internal hub, I wish I had my derailleur and 10 speed free wheel. Never missed a shift on my Trek.Thank you for you input. Do you think the front hub motor is easier on the Nexus then?
What may I ask are you planning on replacing it with ?I have owned two bikes with a Shimano Nexus rear hub. One was on a Breezer Uptown with a 750 watt front hub motor. I bought it used and put 2500 miles on it. It acted flawlessly and never had an issue shifting. I have one on my 2019 Electra Townie Commute Go 8i. It is an 8 speed internal rear hub. The motor is a mid drive Bosch Performance 250 watt motor. I am careful when I shift, usually pause, not to stress the hub. I have close to 1000 miles on it. I like that I can shift to a lower gear, while standing at a traffic light. It has not been great. I seem to have two issues. When shifting it is slow to shift into gear. Second, no matter how many times I or my LBS work on it, when in 5th gear, it will inevitably skip. I was told it was finicky and had to be adjusted just right. After numerous times, I asked if I could have the rear hub replaced, under warranty, I was told Trek wouldn’t authorize it. I will eventually replace it.
Steve: sticking with Bosch makes perfect sense then, being that you have a few extra batteries!Haha yes Court needs a drone cam ! Thanks Mike the price is high so I may make a lower offer. I own several Bosch powerpacks so I am not considering Brose Shimano or Yamaha motors.
That’s a good question, I am not sure, because I have a lot invested in batteries and accessories. I might want a lighter Class 3 e-bike with better handling. With the Class 1 top speed restriction, especially the way Bosch approaches it, you don’t need the top gears. In the meantime, I will try to replace the internal hub with a new one or look into a derailleur and cassette combo. I might research taking one of my bikes and converting it to an e-bike. It won’t be pedal assist but it won’t have the annoying top speed restriction. I can still use the gears and pedal. (More powerful hub motor, twist throttle, new controller, and higher wattage battery).... to be continued.What may I ask are you planning on replacing it with ?
You could buy a delimiter for your Bosch such as the Bikespeed RS. I agree with you about the limitsThat’s a good question, I am not sure, because I have a lot invested in batteries and accessories. I might want a lighter Class 3 e-bike with better handling. With the Class 1 top speed restriction, especially the way Bosch approaches it, you don’t need the top gears. In the meantime, I will try to replace the internal hub with a new one or look into a derailleur and cassette combo. I might research taking one of my bikes and converting it to an e-bike. It won’t be pedal assist but it won’t have the annoying top speed restriction. I can still use the gears and pedal. (More powerful hub motor, twist throttle, new controller, and higher wattage battery).... to be continued.
Thanks, I checked it out, did you get the pre programmed one? Is there a website? How much $$$ and is it hard to install?You could buy a delimiter for your Bosch such as the Bikespeed RS. I agree with you about the limits
It is not very hard ( I got my son to do it ) and it takes about 30 mins. You need a few small tools that they sell as well. It was about 150 Euros as I recall. https://www.bikespeed.de/RS_en.htmlThanks, I checked it out, did you get the pre programmed one? Is there a website? How much $$$ and is it hard to install?
