Replacement Battery connectors
ShortCircuit
I have a AddMotor 350 and the battery connector is messed up. Does anyone know what these are called and where can I buy a pair?
I have a similar connector on my battery and it appears to be proprietary. I have yet to find an exact match.
You can try these:
Or these:
The spacing of the blades may not match however and some modification may be required.
In a pinch I split the plug on an old extension cord
These common crimp on connectors work as well:
These are jury rigs at best but they do work.
Thank you. I was afraid it would be a mystery connector. I cant see spending $600 for a replacement battery just because of a connector issue. I guess I'll use a 30 amp Jones 2 pin plugs and sockets and 3d print housing adapters so they fit the battery and holder.
I really liked the split power cord. That is a MacGyver if I every saw one. Clever. :=)
Actually, I can't take credit for that one. I saw the idea in another thread here at EBR. I don't remember the poster or I would have given him credit.
Why not get that proprietary connector out of the equation? Set the battery up with a short pigtail and your favorite connector, then do the same on the other side. Use quality wire (12ga) and connectors and you should never have any trouble with it.
