Rad city or dj fat tire
Kensr75
So i have it narrowed down to the rad city or dj fat tire. Rad city is direct drive dj fat tire is geared. Both in my price range. As i stated proir mostly to get to work 2.5 mi each way. Pretty flat. Anyway anyone have input on these two bikes. Thanks
Is that all the bike will be used for? Or will there be some recreational use, possibly in more hilly terrain?
I may take a few longer trips. I don't really go anywhere. The longest would be to the dr. 5-6 mi with one long hill the rest is flat. I just dont want to make a bad choice and wish i bought the other one. Looking for in the long run.
Oh man if you're just gonna be using it for commute, just get the Rad City.
Those fat bikes are just loud.. listening to those buzzing bulldozer noise really gets old when you're riding a long straight line.
If you're going to be riding on snow or sand, by all means get the fat bike.
Snow in winter when there is some. I was leaning toward the rad city. Seems more economical. I really just like the looks of the fat tire. Rad city kinda plain dont like rack on the back but cant have everything. So thanks.
What did you mean by "economical"? Did you mean like saving battery energy or to purchase the bike itself?
Anyways, fat tires are absolutely terrible idea if you're looking for efficiency.
Although I'm not an engineer, being a motorcycle enthusiast, I've read a lot of articles written by motorcycle engineers.
If you look up for words like "rotating mass", "rotating inertia" and "unsprung weight" you will quickly find out how bad it is to add weight on wheels.
To put it simply, putting a weight on "moving component", especially rim/tire is whole a lot worse than adding weight on frame.
I know a lot of bicycle companies love to talk about light frame, such as titanium and carbon fiber, however the saving weight off frame doesn't do much.
The overall motorcycle weight (in this case, bicycle) doesn't give you the whole characteristics.
I'll give you an example of "moving component": Think about carrying a 10 lb backpack, will you be able to walk or run normally? The chances are, you can. Because your back isn't a "moving component" when you're walking.
Now, let's put that 10 lb weight somewhere else.. can you walk or run normally when you wear 10 lb shoes? No you cant.
Your overall weight didn't change, but simply moving weight from frame(back) to wheel(feet) has drastic difference.
This is exactly why high performance motorcycle engineers are trying to shave the weight off any moving components.
No wonder I could beat 750W fat bike with mere 350W commuter bike.
On top of added rotating mass, fat tires drastically increase friction too.. it really doesn't make sense unless you're riding on snow or sand.
I guess efficient is the word i should have used. Thanks that was helpful
