Overall, I like my Aurora. Wish I would have known the limited edition was coming before I ordered mine, as the Gates belt drive and the bigger battery and extended range were just about the last remaining boxes that were not checked. The Aurora checked the most of the boxes that I was looking for, step through, mid drive, CVT gearless shifting, being able to shift while not pedaling, as well as auto mode, can also use throttle only, has fenders and rear rack, thicker tires in between road and MTB, front suspension, higher speed up to 28 mph, hydraulic disc brakes.
My initial problem with the battery % remaining was fixed with the display being reprogrammed. Only issue now is a rattling somewhere when the motor is engaged, which I cant really pin down where it is coming from, as it only happens when moving. But, will try to test without the wheel touching the ground to see if I can pinpoint it. When I remove the battery, sounds like there is something inside that is loose and rolling around, but doesnt really sound like that is the cause. Cant do much about it, so hope it is not going to be an issue.
