I have a new Rad Mini StepThru 2 which I'm still getting used to. During the last few rides, I'm having difficulty in switching to a lower PAS level from a higher one while I'm still moving. Specifically from 3 down to 2. When the bike is stopped, switching down from 3 to 2, or whatever, works fine.
Depending on conditions, I usually ride at PAS 2. But when going uphill, I switch up to PAS 3 and when things level back off I switch back to PAS 2 - at least that's what I try to do. The trouble is that the PAS level often won't switch down. I end up hitting it a couple of times trying to get it to work, and it either doesn't switch at all or suddenly goes to 0 (after hitting the down button a few times).
Is there something I'm doing wrong (which is quite possible) or is there a problem with the computer?
Any thoughts on this would be appreciated.
P.S: ...And is it just me, or is there quite a large increase in power between PAS 2 and 3, Compared to between PAS 1 and 2?
Thanks!
Thanks!
