Pedego Trail tracker hydraulic fork
Alejandro_C
Hello, I own a Pedego Trail Tracker eBike, I’m searching for an option to replace de standard fork for one that has hydraulic suspension. The Trail tracker has 26” fat tires.
I found this post, someone has already been successful with the replacement.
thank for any help.
I replaced the OEM suspension forks on my Pedego Platinum Interceptor with Rockshox 30 Gold. It isn't a fat tire bike though. It was an easy swap that took less than an hour. I can't say for sure but the Trail tracker looks like it uses standard wide format suspension. Rockshox makes forks for fat tire bikes such as these:
Check the specs first before buying. You may also need a disk brake mount adapter.
