Park freewheel tool mod
Chopperbill
This has been discussed in Rad Power discussions but I thought others may find use for it. Changing the freewheel on my Rad Rover gave me fits. I did a lot of searching but I could never find the problem. The tool won’t fit over the wire connector or the axle nut that won’t slip over the harness. I finally found where Rad owners have split there tool. I decided to put a knotch in mine. Was very simple with my Dremel. I removed one male and one female spline and dressed up the cut. It took just a few minutes. I plan one taking a piece of key stock and making it fit into the cut grove to keep it from distorting while putting pressure against on it for stubborn freewheel.
Surprised they haven't introduced a hub motor tool yet. One of the advantages of mid drive.
What size is the socket? Tooking for a similar tool for my radmin4, any options out there?
