Nova Haibike
I took delivery of a Trekking RC on Friday, and assembled it that day. The company I got it from, Random Bike Parts (through their eBay store) did a good job of packing it, putting in extra cardboard to protect it during shipping. The first thing I always do is insert the seatpost so I can put the bike into the repair stand. The inside of the seat tube was lubed, but unfortunately there was a burr that scratched up the post.
Should have run a Flex Hone down the tube first. Fortunately I have to run the post all the way down to where the end hits the bend in the seat tube, so the scratches are not visible.
I never trust any factory assembly, so I tend to take many if not most things apart and reassemble and readjust. I find that wheels bearing are always too tight and lacking grease. The wire for the front headlight was very long, so I took the motor off so I could pull the excess into the down tube. The bolts holding the plastic motor shield were incredibly tight, to the point I was afraid I might strip out the 3mm hex heads. I did finally manage to get them loose. They did not appear to have any kind of threadlock on them, but if they did, it certainly worked almost too well. I used anti-sieze to reassemble. On that note, I replaced as many of the 3mm hex bolts on the bike as I could, in favor of 4mm ones; I just hate tiny hex bolts.
I read elsewhere that the front light tends to fall off; IMO the supplied plastic bracket is not very well designed, using screws that just bite into the plastic, instead of bolts that mate with nuts. I put threadlock on the screws. I am not crazy about the lights front or rear; eventually I will replace both with much brighter units. I've glanced at some options by Supernova and Lupine, if I want to continue to run lights off the bike's battery. But I may just use my Fenix BC30R (which is a great self-contained rechargeable LED light).
I am not tall at 5'6"-5'7". I was afraid the 19" I ordered might be a bit too small, but if anything it could be smaller. That said, with my road bike background, the cockpit is too upright and cramped for me. I flipped the stem over to lower the bars some. I could lower the bars more by putting the headset spacers on top, but I hate the way that looks. LOL. The bars feel ridiculously wide to me. I may replace the riser bars with narrower flat bars, and get a longer stem as well. I may even go to a trekking bar, or some other alternative like the Jones H-bar. So far the only thing I have changed is the pedals. I did not go clipless though, which is something I have always used. I opted for Race Face Chester platforms. Too bad the blue isn't quite the same shade as the Cyan accents on the bike.
The battery rattles a bit in its mount. I tried to see if I could adjust the lock cylinder bracket to some degree. I removed the plastic housing, but the two 3mm hex bolts holding the metal plate underneath were...like the motor shield...very tight. Unfortuntely, even using a new-ish 3mm hex tool, one of them got rounded out. I will eventually fix that, but for now I just replaced the other with a 4mm hex bolt. I bought some automotive rubber weather sealing to stick to the frame and fill the gap between it and the battery to keep the battery from rattling, but alas it is not quite thick enough. I will return it and get some large gap foam weatherstrip instead.
So far I have ridden the bike just 33 miles. I wish it was a Class 3 pedelec, and that the PW motor supported high cadences. As fat as I am (240 lbs.
), I can still go past 20mph quite easily. But I knew the limitations when I bought it, and I am happy not to have spent an extra $2-3K more just to get a higher performance motor. I still want speed though, so I'd appreciate feedback on Yamaha tuning kits such as the Blueped, Speedbox 2, etc. if anyone has experience with those.
