How many of the mid-drive manufacturers can share the market? Each with it's own mounting and battery dimensions and probably other unique elements that prevent any possible interchange over the life cycle of the bike.
Like the other significant mid-drive brands this Panasonic will also be an "underperformer" because it will be compliant with the EU's idea of what an ebike should be limited to speed and power wise. I understand that mid-drives are wonderful for slow speed climbing and the weight distribution makes them perfect for mtn bikes but they are not well suited for urban mobility in my opinion.
Mid drives aren't well suited for urban riding ? Not my experience.
Do you spend a significant % of the time above 20mph? Mid drives all have one major problem - While they benefit from gear ratios at low speed they suffer significant mechanical inefficiency at high speeds. Let's say you are riding with a 44T front chain ring and an 11T rear chain ring at 22mph on a mid-drive ebike...you are loosing 75% of the torque the motor generates at the cranks due to this 4:1 gear ratio. This typically results in less torque being delivered to the rear wheel than what is provided by much lower cost hub drives. This is not discussed much in this industry because everyone has been brainwashed into buying into the Class 1 assist limit of 20mph - at those speeds the impact of this issue is not all that noticeable.
Don't take my point the wrong way. I do believe mid-drive ebikes are fantastic but the benefits are best suited for mtn / enthusiasts bikes which tend to have a lot of time climbing at slower speeds where the gear ratio can actually benefit the motor's performance. Obviously having the weight low and centered is a huge plus on those type bikes as well.
With 1500 watts, I can can easily cruise at 30+. I did ride a mid drive Trek and it was a very nice bike but severely underpowered at speed compared to my bike.
If you did 5000 miles+/year on Bafang Ultra, you will end up replacing chain, cassette multiple times.
They may be perfect for off-roading and they are powerful but are simply not suited for long commutes and doing it everyday consistently.
No 5000 mile years for me but I ride around town and the surrounding area with no problems as of yet. If I have to change a chain at 2000 miles, big deal. Easier than a rear tire change on a hub drive. The hub I demoed stalled on a good size hill. My bike walks up it without hardly shifting. I think it's been proven that all the drivetrain problems with a mid drive were exaggerated.
I'll give up having to do some maintenance for a more balanced feel. Hubs just don't feel the same to me.
Why reinvent the wheel? Instead just use what already exists.
I'm thinking SIB630. 20700 powered...
That battery looks mighty familiar to me...
/QUOTE]
JayVee, I agree that pack looks pretty much the same and as you point out contains 20700 cells. However the 20700 cells are a model that are labeled Panasonic/Sanyo and 4250mah max. Data here:
https://akkuplus.de/mediafiles/Datenblatt/Panasonic/Panasonic_NCR20700B.pdf
The Panasonic 21700 cells are 5000mah and would fit in the same casing easily as they are only 1mm longer:
http://eleteks-com.sell.everychina....rain-3-7v-21700-rechargeable-lithium-ion.html
So not so much re-inventing the wheel as making it a better wheel within the existing parameters. No doubt the new cell size will take hold in the eBike world here over the next few years, as well as all other sectors. The 18650 won't go away nor does it need to and probably the price of them will be driven down as a result. But the 21700 battery will make an attractive option as an upgrade when your 4 year old 18650 starts to lose it's capacity given that there is a format developed as a replacement. However because there is no standardization it is going to be catch as catch can I predict.
The real test of Bafang ultra would be if someone were to commute everyday 30 miles at 25 mph. The motor may fail, cassette and chain will give up well before.
A good hub drive with a torque sensor will be a pleasure to ride. The success of Juiced CCX is a proof for that.
completely missed your post here. What is the best tech resource for Panasonic mid drives? I’ve been poking around an electronics channel and again met a FIT rider. Could this be an answer to China tariffs for someone young and a wallet?Panasonic has made mid drive systems for years primarily for the Japanese market. They have been on par with Bosch etc. now for several years but haven't been OEM on many brands, KTM being the exception.
https://www.ebiketuning.com/comparison/panasonic-tuning.html
Their alliance with Kent has shifted gears though it looks like and don't be surprised if that battery doesn't hold the 2170 cells that Panasonic is making for Tesla at the Giga Factory.
https://www.cxmagazine.com/van-dessel-teams-panasonic-release-passepartout-gravel-e-bike
Personally this line excites me more than any other currently available ones from the major manufacturers. I would especially be happy with their eMTB version.
