Trail Cruiser
Hi Court (administrator), I always hear you say that the mid drives are limited by the assist cut off at a not-so-high cadence RPM, so you have to upshift if you want to go faster . Bosch used to have favorable feel since the cut off is 106 RPM so you can pedal fast enough. The assist cut off in Yamaha, Brose, and other popular OEM brands are in the 80-90's RPM. However, things have changed now and you should really check it with a cadence meter especially when you tested the recent Giant ebikes since they now use the new Syncdrive that has higher cadence cut off of 110-120 RPM.
This is from the E-mountainbike magazine: " The pedal-assist on the SyncDrive Pro works in the three strongest support modes with a cadence up to 120 rpm, and up to 110 rpm in the lower two modes. This is another diversion from the Yamaha PW-X, which only supports up to 120 rpm in the most powerful pedal-assist mode." http://ebike-mtb.com/en/first-ride-giant-full-e-0-sx-pro-new-syncdrive-pro-motor/
So your preconceived idea on Mid drives does not apply anymore to this newer models.
By the way, The newer Giant ebike has a cadence meter on it's display panel so there is no excuse not to check it.
