I'm not sure why a set of hydraulic brakes wouldn't just "drop in". Most ebikes I've seen have iso 6bolt patterns on the hubs, standard 74mm post mount or 51mm frame mount spacings. Let's say you wanted to swap out your cable brakes for say Shimano 8000 series brakes. Choose the rotor size ex. 180mm; choose the caliper mounting bracket that corresponds to your frame or fork mounting dimensions and disc size. mount the disc, mount the caliper bracket, mount the caliper, make your centering adjustment and you should be good to go. Unless there is some specific odd ball brake on that bike , this should work. From what I've read , Pedego uses decent components. I bet my lunch it would work.
